Dizzy question
Old Apr 12, 2007 | 07:11 PM
91 ef hatchback's Avatar
Default Dizzy question obd1?
just want to check if the coil and dizzy plug for the resistance and voltage... anyone know where i could find a chart or diagram for this... o and it is obd1, thanks
Old Apr 12, 2007 | 07:38 PM
Formula's Avatar
Default Re: Dizzy question obd1? (91 ef hatchback)
What engine is in your car? And what Distribitor is in your car?
The Ignition Control Module resistance for most Civics is 1.1 to 3.3 K-ohms.
The primary resistance for most Civic and Integra coils is 0.6 to 0.8 ohms and the secondary resistance is 12.8 to 19.8 K-ohms.
If your car has a Hitachi distributor the primary resistance would be 0.45 to 0.55 ohms and the secondary resistance is 22.4 to 33.6 K-ohms.
If you need more info you can look in a Helms or Haynes manual for your car or engine that you have.
Old Apr 14, 2007 | 05:15 PM
Default Re: Dizzy question obd1? (Formula94)
how would i find out what dizzy it is... where would the markings be at... its a d15b1 with a y6 head i belive but i dont know how to tell the vtec heads apart
JDM Lyfestyle
May 31, 2008 12:12 PM
si0385.
May 25, 2006 12:47 PM
marc-111
Jul 1, 2005 11:36 AM
fiftee_su
Dec 11, 2004 05:34 PM
