weird headlight problem ? -- 94 civic DX
Old Apr 12, 2007 | 07:03 PM
vivithemage's Avatar
Default weird headlight problem ? -- 94 civic DX
Odd problem with my new headlights (and even my old) the 'bright bulb' on the right side does not work when i turn the brights on (at least on the right side it doesn't work, but the left works fine), and when I hooked the right headlight up to the left side it worked fine, SO it's a wiring issue, my guess was that the left sides hookup's corroded, which could also lead to my problem why my right sides blinker light stays on and not my left sides! (or maybe they aren't supposed to be on at all! I don't even know.
ummm, anyone ever hear of this? Or have any hookups for sale? I posted an ad on the marketplace forums already, soo lmk if there is an easier fix then bothering someone else for there hookups.
Old Apr 12, 2007 | 07:54 PM
high_revs's Avatar
there are 4 fuses underneath the dash for the headlights, one of them is popped....should be a 10 amp fuse.
Old Apr 12, 2007 | 08:07 PM
Default Re: (h2b_eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote">there are 4 fuses underneath the dash for the headlights, one of them is popped....should be a 10 amp fuse.</TD></TR></TABLE>
so you think it has nothing to do with the corrossion ?
Old Apr 12, 2007 | 08:10 PM
high_revs's Avatar
probabbly not, check the fuse, i had this same issue 2 days ago
bdptcob
13
Jul 8, 2006 08:11 PM
Dc2 Powered
Jul 14, 2005 08:23 AM
e-lauckd
Aug 20, 2001 05:10 AM
