Pistons?
Old Apr 12, 2007 | 06:35 PM
1995Civiccx's Avatar
Default Pistons?
Ok i'm building a b18b block. I'm stuck on what pistons to get. I plan on boring it out to a 2.0 liter. And i plan on getting high compression pistons. But i don't know which to get. I was thinking civic type-r pistons but I heard those aren't good for daily driving. What would you recommend?
Old Apr 12, 2007 | 06:37 PM
shrums-EG6's Avatar
cp pistons is a very good company. but are you boaring it out on stock sleeves or are you sleeving the block?
high_revs's Avatar
try something non oem honda if your gonna bore it to a 2.0...something forged..
Old Apr 12, 2007 | 06:42 PM
Default Re: (h2b_eg8)
yea i plan on sleeving it. I'm still working on the list of parts i would need.
Old Apr 12, 2007 | 07:08 PM
doood's Avatar
been there done that
Default Re: (1995Civiccx)
now's a good as time as any to learn you cant use oem pistons with an 84-85mm bore
Old Apr 12, 2007 | 07:11 PM
DAneronimo's Avatar
i like the cp's also. i have the x-forged lightweight ones. the only problem with using them for your build is that if you are going to bore it that much, you will have to have them custom made for you. they are nice and light though. mine are 81.50mm 12.5:1cr, and they are lighter than a 9.0:1cr piston.
Old Apr 12, 2007 | 07:13 PM
high_revs's Avatar
Default Re: (DAneronimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAneronimo &raquo;</TD></TR><TR><TD CLASS="quote">i like the cp's also. i have the x-forged lightweight ones. the only problem with using them for your build is that if you are going to bore it that much, you will have to have them custom made for you. they are nice and light though. mine are 81.50mm 12.5:1cr, and they are lighter than a 9.0:1cr piston.</TD></TR></TABLE>
how much did you pay? they make custom h/f series applications as well i suppose?
Old Apr 12, 2007 | 07:17 PM
DAneronimo's Avatar
i would assume. i think they will make anything you want. i didnt have to buy custom made pistons. i got lucky since the ones i needed happened to be one of their "shelf" pistons. i paid $540 for them, and i dont remember how much more it is to have them custom build you a set. i think it tells you on their site.
Old Apr 12, 2007 | 07:19 PM
high_revs's Avatar
cool...sounds good, once i get to that point i will see all my options/companies
hoffmanb16
30
Oct 30, 2017 03:41 AM
Wheelman-CZ
Jan 7, 2008 12:52 AM
Mydogisgone
Feb 21, 2007 07:05 AM
v4lu3s
Jul 19, 2004 12:45 PM
Watkinsm3
Apr 9, 2003 09:57 AM
