94 civic fog light install
hey guys, we need to install the fog lights on a 94 civic si coupe (cdn) and want to know where to cut out the fog light holes for the bumper. Does anyone have a picture of it?? people say follow the groves but the only groves we see is around the edges of the bumper.
Before you say "search" I did and the DIY thread has been removed for some reason, so if you can find one with pics plz post it up thanks.
just look at any picture of a civic with fog lights, you should be able to tell where to cut. you cut out all the plastic in that area, it should all be black unless the bumper as been repainted or something. just remember to check twice cut once, once you cut too much you cant go back.
after looking at many pictures we got the bumper, now the problem is that the bracket doesnt line up
only one bolt lines up but the housing of the light will not fit on the grille. does that make sence at all?
u said only 1 of the 3 screws will line up??
my guess is the one thats on the top next to that little nipple......
for u to get the other 2 screws in just push the bracket a little bit and get one screw in at at time...(but dont tighten it all the way down yet)
if u need more help LMK... i did mine like a month ago
i thought thats how it would work also knightx, but it didnt. Stupid egay fog lights were cut out wrong on the bracket. We made a slight modification and drilled new holes on the foglight housing to make it fit and it worked. Thanks guys for the help we got er done after staying up till 4am and deciding to just "force it to fit"
Modified by integra DA9 at 2:30 PM 4/14/2007
dumb question here!!!
if the former owner cut the holes for the fog lights and cut it too big because he had turbo... and the fogs i got slip through the holw.. does that mean i gotta buy a new bumper?
basically the hole is too big for my fogs.
white4doorsi
Mar 6, 2007 12:30 PM
02CivicSiVeloz
Oct 25, 2005 08:39 PM
