clutch issues
okay i got a 95 honda accord 5spd ex with 165k miles and i gota XTD stage 3 racing clutch along with i believe a 10 or 11lb flywheel. okay its been 2000 miles ago and i notice that my pedal isn't stiff at all like it use to be.. pedal feels like it losing pressure and also i tried bleeding it no luck.. pedal engages all the way at the bottom.. never was like.. also master cylinder isn't leaking nor is the slave cylinder but yet again it was replace 3 months ago.. help me out please..
did you try taking it back to them? if there is only 2000 miles on it and everything else checks out, the work they did might be the culprit.
a few mins ago the clutch felt nice and stiff.. i don't know whats going on but i have a feeling th bearing is the culprit.. if bearing gets noises what are other signs of it.. and if it goes bad will the clutch pedal stay to the floor?
bubs
Jun 2, 2005 11:51 AM
