searched- cold start valve removal
so i got my h22 swap started and it has an eratic idle. but if you put your finger over the hole in the trottle body it runs normal. so i want to just remove the cold start valve. The problem is it wont stay running when cold, without the valve. (weird!) how can i fix this?
Try removing the fast idle valve and the 2 little screws on the back of it, under the plate there is a screw that you'll need to tight. There's a special tool for that screw but you should be able to tight it with longnose pliers or screwdriver.
this should fix your issue. . .
http://92lude.com/idle_air_control_bypass_mod.htm
it sounds just like the problem you have described. hope this helps
mashguy4077
Jun 2, 2013 10:17 PM
92cb7sk8er
Jun 21, 2011 12:34 PM
GetSTROKED
12
Sep 1, 2006 09:46 PM
