Whole bunch of questions.
Old Apr 12, 2007 | 04:01 PM
honda_racing101's Avatar
Default Whole bunch of questions.
Alright well heres the story. Im putting power steering in my del sol S, and if you guys didnt know, the sol S's rack is much smaller in diameter than the power steerings. Where the S mounts the rack to the 'subframe' (dont know what its actually called) its flat on the passenger side, and on power steering models its indented to compensate for the larger diameter. Well, upon seeing this, I tried to drill a hole in the piece that holds the rack on the passenger side, well uopn doing this I found I needed a smaller bolt head so I got a new bolt, ground the head down even more, but by mistake I crossthreaded the screw. So I came to the conclusion that I needed to switch the 'subframes' so I could have the indented part.
Heres some pics.
Off of this car:
Has anyone else ever done this before?
Here you can see the carnage of the piece I described. Does anyone have one of these?
Does anyone know how to get the pins that hold this sensor off?
Heres a GSR mount, will this work with my b16 del sol? The dude I bought it from said it will but idk, if it does how do I put it on?
Please read and try to help me, I would REALLY appreciate it.
Old Apr 12, 2007 | 04:20 PM
Bejita's Avatar
http://www.hondaautomotivepart...8S%29
Old Apr 12, 2007 | 05:08 PM
Thanks for the site, but the one you have listed is for manual steering.
Old Apr 12, 2007 | 06:31 PM
top.
Old Apr 13, 2007 | 03:17 PM
Come on, does anyone know if the mounts will work or how to get those tabs off?
Old Apr 13, 2007 | 03:25 PM
NACvicSi's Avatar
Not to rip on ya, but just wondering why you need power steering in this tiny car (also a Del Sol owner)
Old Apr 13, 2007 | 03:48 PM
Well, idk I was just used to it and since theres no engine in my S and the parts are available from my wrecked sol, I figured why not?
Im about 6'3'' 210lbs, so turning a wheel wouldnt be any problem, but hell im not the only one who drives it and like I said I was used to it so why not.
But hey ya think you can answer either of my questions?
Old Apr 14, 2007 | 12:36 PM
Will this GSR mount work or not?
Old Apr 15, 2007 | 09:56 AM
Come on guys I jus needa know if a GSR mount will work on a b16 in a sol.
Old Apr 15, 2007 | 10:00 AM
92ehatch's Avatar
Default Re: (honda_racing101)
that sensor is the tps.
those are actually screws in it, just slot the top of them and use a flat head on them. they will unscrew.
then to make it easier down the road, go get some bolts for it instead.
Old Apr 15, 2007 | 10:03 AM
You mean like pound a slot in them and use a flathead to unscrew them?
Old Apr 15, 2007 | 10:06 AM
pakman89's Avatar
Default Re: Whole bunch of questions. (honda_racing101)
for those tab on the sensor i've always used a chizzle and hammer just hit it at an angle and the should start turning after a few hit you should be able to loosen it by hand
Old Apr 15, 2007 | 10:16 AM
And then to replace it just buy hardware that will work?
Anyone know about the mount?
Old Apr 15, 2007 | 10:21 AM
imbillkamal's Avatar
bump for answers,
wish i could help ya
Old Apr 15, 2007 | 10:26 AM
Thanks.
Anyone know?
I needa get another mount ordered if this one doesnt work.
Old Apr 15, 2007 | 12:12 PM
Top.
Old Apr 15, 2007 | 05:53 PM
GSR mount with a b16a3..yes or no?
Old Apr 15, 2007 | 06:50 PM
sauceja's Avatar
The mount on the engine won't work. You will have to swap it over to the gsr mount in the picture. Otherwise it will be at the wrong angle. The 2 bolt mount bracket is for the ef civic/crx.
don't know about powersteering, not a fan of it. If my wife drives my car she just has to deal with it.
That and no a/c.
Good luck.
Old Apr 15, 2007 | 06:57 PM
egmatt93's Avatar
Default Re: (sauceja)
the mount will work great i did it on my b16 and it sits the motor great. thing that sux though is u have to get that timing belt cover off to get it on . after the cover is off though its a piece of cake
Old Apr 18, 2007 | 12:51 PM
Will the GSR mount bolt perfectly to the previous spot and bolt to the A/C bracket that wraps around?
Old Apr 18, 2007 | 12:58 PM
Blk00EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja &raquo;</TD></TR><TR><TD CLASS="quote">The mount on the engine won't work. You will have to swap it over to the gsr mount in the picture. Otherwise it will be at the wrong angle. The 2 bolt mount bracket is for the ef civic/crx.</TD></TR></TABLE>
Ditto. To get all that plastic shielding off you have to take the crank pulley off and that can be a bitch. I'd say try to get your money back from that mount and get the right one. GSRs and Type Rs use a different style mount than the other Bs.
Old Apr 18, 2007 | 05:36 PM
Well then its settled, i'll try n get my money back n get the correct mount.
Old Apr 19, 2007 | 07:20 AM
auto-accessories-inc.'s Avatar
* B A N N E D *
1.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egmatt93 &raquo;</TD></TR><TR><TD CLASS="quote">the mount will work great i did it on my b16 and it sits the motor great. thing that sux though is u have to get that timing belt cover off to get it on . after the cover is off though its a piece of cake </TD></TR></TABLE>
2.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja &raquo;</TD></TR><TR><TD CLASS="quote">The mount on the engine won't work. You will have to swap it over to the gsr mount in the picture. Otherwise it will be at the wrong angle. The 2 bolt mount bracket is for the ef civic/crx.</TD></TR></TABLE> there are two people saying it will fit- just needs a little muscle and effort. like i told you that mount cost $12 to ship i charged you $20 shipped i made $8 bucks so if you send it back im only going to refund you $8 i guarenteed you a b-series mount from a b18 into an eg hatch it is the buyers responsibility to make sure it fits before they purchase, i sell the stuff not research thats why i charged almost nothing for the stuff- like i said just resell it i think i have a guy who needs one ill try and get a deal then you can just mail it to him
Old Apr 19, 2007 | 08:18 PM
Blk00EJ8's Avatar
Default Re: (srt42004n)
If that's true then just resell it. Actually those 2 people are saying essentially the same thing but the first quote doesn't know that it doesn't fit the B18C. It will fit the B16 like stated.
Old Apr 20, 2007 | 04:41 AM
Yes, it will fit if I take everything else off but srt42004n what I tried telling you was I wanted only the rubber mount to work, and not the entire thing.
