Another Wheel/Tire setup ?
Please examine my setup before I buy!
Volk TE37s
+48mm
Bolt Pattern: 5-114
17x9
Offset: +65mm
Bolt Pattern: 5-114
I planned to run 225 45 17 in RT615
and 255 40 17 in the rear.
Any comments on potential problems? TIA.
Volk TE37s
+48mm
Bolt Pattern: 5-114
17x9
Offset: +65mm
Bolt Pattern: 5-114
i see no problems with that setup, you will easily clear everything. you could probably even afford to go a little wider if you desired.
Black R
Jul 15, 2002 01:45 PM
