Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Distinguish between 91-95 Legend GS and LS
Old Apr 12, 2007 | 02:34 PM
SiRTifiedacc's Avatar
Default Distinguish between 91-95 Legend GS and LS
I was taking a look at some Legends and wanted to know how you can distinguish the LS from the GS, I believe both have 3.2s. I know the GS is equipped with the dual piston calipers. But what physical differences? Sunroof? Rims? Leather..? etc.
Old Apr 12, 2007 | 04:14 PM
Kenso's Avatar
HT White Ops
Default Re: Distinguish between 91-95 Legend GS and LS (SiRTifiedacc)
The GS has a body colored grille surround whereas the L/LS has a chrome one. The GS will have the 5 spoke monoblock style 16" rims, the L/LS will have multi-spoke 15" rims (although plenty of people have put GS rims on the lesser models as an upgrade, so it's not a sure sign). GS has a 160mph speedo and the Type II motor with a badge on the intake manifold, others have 140mph speedo and no Type II (unless it's been swapped in). The GS was only available in 94-95, so if it's a 91-93 it's definitely not going to be a GS. The GS will have traction control and the others will not. Those are some of the most obvious differences. Also, in case you didn't know, the GS is only available as a sedan, top of the line coupes are LS's.
Old Apr 12, 2007 | 05:10 PM
Default Re: Distinguish between 91-95 Legend GS and LS (Kenso)
thanks kenso you the man
91EF919
Aug 7, 2009 08:32 PM
jdmcivic1
Jun 6, 2007 11:30 AM
espanol
Mar 18, 2003 01:59 PM
JV
Jan 26, 2002 03:27 PM
