b18C with N1 pulley
Old Apr 12, 2007 | 12:51 PM
Hatch_Back_97's Avatar
Default b18C with N1 pulley
Hey guys, anything at all related to the CTR N1 race puley would be helpful. I installed it to replace the UR underdrive pulley mainly because I did not like underdriving ym alternator. I have no A/C or P/S in my 97 hatchback and this N1 installed now. Anything with blancing or bearing wear problems? Only REAL smart guy post a reply please...no hearsay or flaming...peace!
setup: JDM B18C with 20K (+/-) on it, AEM Hybrid cold air intake, Nology hotwires and external coil cap and coil, OBX 4-2-1 header, Magnaflow 2 1/4" catback with B pipe.
Old Apr 12, 2007 | 01:03 PM
Padawan's Avatar
Darth ModerVader
Default Re: b18C with N1 pulley (Hatch_Back_97)
To date, there has been no direct, conclusive evidence that such pulleys cause any engine damage. Some people will argue that they do, many others use them and experience no issues whatsoever. Take from this what you will.
Old Apr 12, 2007 | 01:07 PM
Default Re: b18C with N1 pulley (Padawan)
Thanks man, thats what I have been hearing as well.
Old Apr 12, 2007 | 01:09 PM
Archidictus's Avatar
Unceasing Measure
While Padawan is correct and the pulley probably won't do direct damage to anything, your car isn't at a point where it's going to help anything either. For safety and reliability of your accessories, I would get a stock crank pulley and call it a day.
Old Apr 13, 2007 | 12:33 PM
Another Q...stock B18C1's are recommending 5W30 oil, thats what I have but now I am staioned in GA where it gets 90-100 regularly int he summer...should I up the weight or add some Lucas additive?
Old Apr 13, 2007 | 12:54 PM
Padawan's Avatar
Darth ModerVader
Default Re: (Hatch_Back_97)
No, 5W-30 will be fine in those temperatures.
Old Apr 13, 2007 | 01:18 PM
Bense's Avatar
Default Re: b18C with N1 pulley (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">While Padawan is correct and the pulley probably won't do direct damage to anything, your car isn't at a point where it's going to help anything either. For safety and reliability of your accessories, I would get a stock crank pulley and call it a day.</TD></TR></TABLE>
it's good for show points though.
*rolls eyes
Old Apr 13, 2007 | 01:47 PM
Padawan's Avatar
Darth ModerVader
Default Re: b18C with N1 pulley (Bense)
Actually, the Honda N1 pulley is quite "bling-less", which is nice. I prefer the plain silver anodized Unorthodox pulley, since it is a bit lighter, allows for the retention of A/C, provides slight under-driving, and looks closer to a stock pulley than the bright red or blue versions.
Old Apr 16, 2007 | 11:09 AM
Ok, its got about 25K miles on it...what about boost...I know 90% of what to do...but what about stock parts turboed. Can I push 6psi with just a thicker headgasket, ECU tune (OBDI) and proper FMU?
Old Apr 16, 2007 | 12:47 PM
Padawan's Avatar
Darth ModerVader
Yes, 6 psi is certainly possible on stock internals with the proper tuning.
Old Apr 16, 2007 | 12:55 PM
doood's Avatar
been there done that
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_Back_97 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, its got about 25K miles on it...what about boost...I know 90% of what to do...but what about stock parts turboed. Can I push 6psi with just a thicker headgasket, ECU tune (OBDI) and proper FMU?
you can reliably make 250-300whp on a bone stock b18c1 with a proper fuel system and tune. an fmu is not a proper fuel system.
Old Apr 16, 2007 | 01:43 PM
envee's Avatar
if you are getting a tune fmu is not necessary anyway. anything other than a stock pulley is purely aesthetic.
Eran
10
Sep 26, 2006 01:35 AM
powerofdreams
Jun 8, 2005 02:21 PM
PearlCrx
32
Jan 27, 2004 08:33 AM
2fstGSR
Oct 8, 2002 02:56 PM
