"JDM EK9 CTR" Pedals in USDM Civics?
http://yhst-1408381693991.stor....html
I came across these and now I'm really curious if they'll work on USDM civic's without modification...
Anyone know?
Anyone know?
I'm not too much of a fan of pedal "covers". I'd rather have the entire assembly put in there to have the feeling of having something "genuine" in there instead of something ghetto rigged.
From: Land of the Hillbillies and Shotguns, Ontario, Canada
They are the actually the whole pedal assemblies so no drilling ios required. You need to change the whole pedal and lever. I'm 90% sure it will fit, but e-mail that store and ask them
These are simple to install just swap the clutch and the gas pedals but as you mentioned before the brake pedal is the one that dose not have proper fitting. I have just finished with this install and I was shipped the brake pad just by itself so that you use the stock brake one. Just remove the plastic and drill three holes on the pedal. Remeber to use the brake pad as a template and they actually are riveted in and not bolted on . There you go and enjoy the new feel.
EPthreeHATCH
Jan 17, 2006 06:01 AM
