4th has lazy starts
Old Apr 12, 2007 | 09:46 AM
Bruce Banner's Avatar
Default 4th has lazy starts
My 93 is having some really LAZY starts in the morning.
I have to hold the key in the crank position for like 2-3 seconds, before it starts.
then the car SHAKES and it starts.
It usually does this after 10+hrs of not being started.
So like over parked over night, or parked at work and I work long hrs.
Any ideas what it could be?
Battery is good, so I doubt battery it's a 1yr old deep cycle.
Old Apr 12, 2007 | 11:57 AM
SkimN's Avatar
Default Re: 4th has lazy starts (Bruce Banner)
you could have a voltage drain somewhere, so while the car is off the battery isn't being recharged by the alternator, its like if you put the key in the acc. position and listen to your radio awhile, it will struggle to start because the battery is drained
Old Apr 12, 2007 | 12:19 PM
Twixle's Avatar
ate my pixel
Default Re: 4th has lazy starts (skimNrace)
If the car is cranking but not starting for several seconds the solenoid on your starter is probably going out.
Old Apr 12, 2007 | 12:49 PM
Default Re: 4th has lazy starts (accord2021)
I've been told possibly carbon buildup in the starter relay.
Jessica010!
Nov 15, 2017 10:45 AM
jorge59la
Sep 27, 2007 07:24 PM
SiB16A
Jun 11, 2006 12:37 PM
rafiq7
Dec 14, 2004 07:46 AM
95hybridcivic
May 1, 2002 04:55 PM
