3mm or 1/8" Wheel Spacers that will fit under rotor for Prelude brake swap
Old Apr 12, 2007 | 09:12 AM
DragWerks's Avatar
Default 3mm or 1/8" Wheel Spacers that will fit under rotor for Prelude brake swap
Anybody know where to get 3mm or 1/8" wheel spacers that will fit under the Prelude VTEC Front Rotors? I ordered some off ebay but the diameter was too large and they didn't fit.
Old Apr 13, 2007 | 02:17 AM
DragWerks's Avatar
Default Re: 3mm or 1/8" Wheel Spacers that will fit under rotor for Prelude brake swap (DragWerks)
bump
Old Apr 13, 2007 | 06:14 AM
highroller54's Avatar
dont put shitty *** spacers between the rotor and hub. Have your caliper bridges milled, much safer!
Old Apr 13, 2007 | 09:34 AM
DragWerks's Avatar
Default Re: 3mm or 1/8" Wheel Spacers that will fit under rotor for Prelude brake swap (highroller54)
^ easier/cheaper said...
Old Apr 14, 2007 | 10:18 PM
BrakeExpert's Avatar
I just found this thread.
I actaully do the machine work, I charge 50$ for a pair of brackets. I do use a milling machine and I take off exactly .127" because I found that to be the best. This doesnt reduce the bite of the lug stud and you still have your hubcentricness of the rotors. PM me if you'd like more information.
DAchiko
Sep 9, 2007 09:11 AM
V-SPEC 1
Apr 2, 2007 10:29 AM
Import_spoon
Dec 18, 2006 12:22 PM
Seedc2
Aug 22, 2004 04:03 PM
HotWheelz
Oct 11, 2002 10:11 PM
