P30 pistons, brand *new* in the box
got a set of 4 P30 (ek civic type R, B-series engine) pistons at my brother's house in Connecticut that I need to sell.
Great upgrade for GSR block with Type R heads. Will fit any B-series motor.
Will take $200 for the set picked up. (price is always subject to negotiation)
Actually, the P30 pistons arent from a Civic Type R (B16B). The P30 pistons are from a JDM B16A. B16B pistons (CTR pistons) are labeled PCT. Those pistons are slightly higher in compression than USDM ITR pistons. In a stock GSR, ITR pistons will give a CR of 11.04:1, whereas the P30 pistons will give 11.5:1.
Good luck.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sirfallsalot243 »</TD></TR><TR><TD CLASS="quote">Actually, the P30 pistons arent from a Civic Type R (B16B). The P30 pistons are from a JDM B16A. B16B pistons (CTR pistons) are labeled PCT. Those pistons are slightly higher in compression than USDM ITR pistons. In a stock GSR, ITR pistons will give a CR of 11.04:1, whereas the P30 pistons will give 11.5:1.
Good luck.
Incorrect.
PR3 = B16A
P30 = B16A2
PCT = B16B
Your compression ratios are also slightly incorrect:
PR3 will put your compression around 11.1:1
P30 will have your CR near 11.33:1
PCT Puts the CR around 12.6:1
Good luck.
</TD></TR></TABLE>Incorrect.
PR3 = B16A
P30 = B16A2
PCT = B16B
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 »</TD></TR><TR><TD CLASS="quote">
Incorrect.
PR3 = B16A
P30 = B16A2
PCT = B16B
PCT Puts the CR around 12.6:1 </TD></TR></TABLE>
Incorrect. All USDM B16's came with PR3 pistons. JDM B16A's came with P30's. And my compression ratios are spot on. Check http://www.zealautowerks.com if you dont believe me. And every compression ratio calculator is different, numbers will vary slightly.
According to that site- with an otherwise stock GSR:
P30 = 11.5:1
PR3 = 11.28:1
PCT= 13.09:1
Incorrect.
PR3 = B16A
P30 = B16A2
PCT = B16B
P30 = 11.5:1
PR3 = 11.28:1
PCT= 13.09:1
sigh...
Im not going to get into this argument, again. And let me correct myself: I thought you were implying that PCT = p30... -> Misread.
Bump for a great deal.
Modified by Circuit Star-29 at 1:11 PM 4/12/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 »</TD></TR><TR><TD CLASS="quote">sigh...
Modified by Circuit Star-29 at 1:11 PM 4/12/2007</TD></TR></TABLE>
No, the OP was implying that P30 = PCT. I corrected him.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pstereo »</TD></TR><TR><TD CLASS="quote">cool, this was a lot of info hehehehe
But yes, they are the Civic Type R P30's (JDM)</TD></TR></TABLE>
Lol, we just went through that. No they arent. Civic TypeR pistons are PCT.
P30 is from a JDM B16A, which didnt come in a CTR.
No isht?? I thought it did. hmm learn something new everyday.
Wait, didn't one of the JDM version of the DelSol have these?
</TD></TR></TABLE>No isht?? I thought it did. hmm learn something new everyday.
GsrSleeper18
Apr 1, 2005 03:55 PM
