About a throttle body gasket
Well awhile ago i just purchased a skunk2 throttle body 68mm and it came with the gasket...but not too long after trying to port out my intake manifold i lost it...does anyone know where i can find one? or you think i might be able to cut out alittle from a stock gasket to match it with the throttle body?
thanks for the input!
Contact skunk2 and see if they can get you one with the 68mm diameter. If not, go to a local auto parts store and pickup a regular gasket and try to cut it out to the correct diameter
i tried contacting them through email, and they said they would quote me on a price but i havent heard from them for awhile, so i dont think ill be getting a response from them
Be aware that the tb gasket that Kragen and Autozone sells for a manual trans Integra is the wrong gasket. If you open it, you can't return it. If you tell them your Integra is automatic, it comes up as the right gasket, but they don't carry it. I had to search all the local parts stores and finally I found one single gasket at the warehouse of a Worldwide auto parts. I was in a hurry, otherwise I would have got it from the dealership, which is what you should do since it isn't any more expensive.
zach1288
Feb 6, 2009 07:29 AM
