Help me choose which rod/main bearings to order!
Old Apr 12, 2007 | 07:51 AM
crexer's Avatar
Default Help me choose which rod/main bearings to order!
Ok, building a b18c1 and I have gone by the numbers, letters on the crank/rods but what I come up with is different than the bearings actually installed. Maybe my motor was rebuilt once before or was done incorrectly. Ok so I have my crank micropolished at the local machine shop and he gives me a paper with MIC numbers like this:
Rod:
1.7713
1.7712
1.7711
1.7708
Main:
2.165
2.1651
2.165
2.165
2.1651
Which colors should I order for my build? I am still planning on plastigauging them but I just need to know roughly which bearings will be within spec.
Thanks for your help
Old Apr 12, 2007 | 09:10 AM
Grand's Avatar
Youl should have the big end's of your rod's measured aswell as your main cap bores before anyone can answer this.
Old Apr 13, 2007 | 01:34 PM
cnydc2's Avatar
Default Re: Help me choose which rod/main bearings to order! (crexer)
This may help:
https://honda-tech.com/zerothread?id=715490
Old Apr 13, 2007 | 03:14 PM
Combustion Contraption's Avatar
You need to measure the inside diameter of the main bearing bores and the big end bores of the rods. Then you will know what you have to work with.
dieselwilly
Honda Civic (2001 - 2005)
Nov 23, 2014 03:20 PM
jakscivic
Feb 21, 2013 08:27 AM
sixtodc4
Jan 20, 2008 09:33 AM
LovinVTEC4
Jun 13, 2007 04:21 PM
crexer
Apr 12, 2007 01:05 PM
