keyless entry/alarm on Manual locks?
you do not have to convert to manual locks,but it would be a lot nicer because then youll have the convience of everything all on one remote.
you can add on the dei 524t fairly easily if you have any mechanical skills and have reliable power locks..but the alarm isnt dependant on the power locks in order to work
Yes you can install a "key-less entry alarm", [they are all key-less entry alarms] into a car without power door locks, if that's what you meant?
You can easily turn your "manual locks" to power door locks and have key-less entry, just add a door lock actuator to each door, better yet, get a central door lock system, Audiovox makes a pretty good, inexpensive one, then all you need is low current ground door lock/unlock outputs from the alarm to give you key-less entry.
94
94
B_Swapped93
Mar 19, 2015 07:31 AM
