ordering OEM parts (cylinder head & block kits)
Old Apr 11, 2007 | 07:40 PM
itr1235's Avatar
Default ordering OEM parts (cylinder head & block kits)
my question is does the cylinder head gasket head and block kit come with ALL the gaskets. if not what else do i need to order.thanks
nothing i have found tells me what is included in the kits
Old Apr 11, 2007 | 08:02 PM
RStoR's Avatar
Default Re: ordering OEM parts (itr1235)
I just made this order. Here are from my notes
06110-P73-A03 OEM ITR Head Gasket Kit
Includes:
• Head gasket
• Intake manifold gasket
• Exhaust manifold gasket
• Valve cover grommets x8
• Valve cover gasket
• Spark plug tube seals x4
• Cam plug
• Cam seals x2
• Distributor "O" ring
• Intake valve stem seals x8
• Exhaust valve stem seals x8
• Dowel pin "O" ring
• Intake orifice "O" ring
• Exhaust orifice "O" ring
• Exhaust "A" pipe gaskets x2
06111-PR4-020 Lower End Gasket Kit
Includes:
• rear main seal
• front crank seal,
• o-ring seals for water tube
• oil pan gasket
• oil pump pickup tube gasket
• water pump seal
IBriaIN
Feb 23, 2011 07:30 AM
DCf4i
11
Jan 7, 2008 01:44 PM
SPD DMN
Sep 19, 2006 05:04 PM
prostreetonline
May 3, 2006 04:36 PM
prostreetonline
Nov 9, 2005 09:05 AM
