weird noise from my headers?
just recently my car was making a noise that i've never heard of...it seems to come and go at times.... it seems to be coming from my headers but i'm not sure...do anyone know what the noise is? bothers me when i hear it ..lol...i'll post up a video of the noise in a while....
are all your gaskets sealing properly? u can get a nasty hissing sound if one of your gaskets fails.
Also, a header will give u a different( louder) exhaust tone than stock, but it shouldn't be "a bad sound"
well while we are on this bad noise topic. it mightb e my clutch ir might be something else. but usually on 1st gear i hear this vibraating nouse on either the front of the fire wall or blow me. i looked there i dont see anything loose. any idea guys?
it sounds like the 2 bolts that connect ur header to ur piping are loose.. and the spring shaking around make that noise.. cuz my civ sounded like that too and i took it to the local shop and they said that the bolts were just loose.. but it could be different in ur case
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM2***** »</TD></TR><TR><TD CLASS="quote">it sounds like the 2 bolts that connect ur header to ur piping are loose.. and the spring shaking around make that noise.. cuz my civ sounded like that too and i took it to the local shop and they said that the bolts were just loose.. but it could be different in ur case</TD></TR></TABLE>
well. if this is the case. is the space between the firewall and the header wide enough for me to go under my car and do it? the header's on a d17 are located on the back close to the firewall right? so i gues ill get a friend to rev my engine while im under it to find out which bolt is loose. then tighten it... if im right give me a BINGO!! hehe..
duuudeeee the header is in the front... lol just get a jack and 2 jack stands. jack the car up from the cross member in the front and put the 2 jack stands under the jacking points under the front 2 doors. then just tighten both bolts and rev the engine. tighten the bolts when the motor is cold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Rules »</TD></TR><TR><TD CLASS="quote">no it has a header in the back buddy</TD></TR></TABLE>
Not on the D17
Buddy
Not on the D17
Buddy
They're on about a K, buddy.
The first guy says headerS, they second chap is correcting him by saying, effectively, that his engine has only one bank of cylinders buddy.
i know that k series have their header in the back.......i was saying cause EM2***** said that K series has headers in the back buddy so i reply by saying no it has a header in the back buddy....k series in back and d17 in front
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Rules »</TD></TR><TR><TD CLASS="quote">i know that k series have their header in the back</TD></TR></TABLE>
Yeah, i know... i was fighting your corner for you...
atleast he's confident for being so wrong
