couple questions on b20 vtec
im doing a b20 vtec swap into either my 90 crx or my 95 eg, i need a couple parts to finish my build, im using the b16 head . i need an oil pan, crank pully, vtec solenoid, and intake manifold. my questions are:
will and b series oil pan or crank pully work?
what about alternator?
also whats the best intake manifold?
and can i use any b- series vtec solenoid?
i think thats it that i can think of right now? anymore advice i would love to hear it thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luda-tec »</TD></TR><TR><TD CLASS="quote">im doing a b20 vtec swap into either my 90 crx or my 95 eg, i need a couple parts to finish my build, im using the b16 head . i need an oil pan, crank pully, vtec solenoid, and intake manifold. my questions are:
i think thats it that i can think of right now? anymore advice i would love to hear it thanks</TD></TR></TABLE>
I'm building a B20V as well, and just so you know what I'm doing, I'm using a B20B Oil Pan and the B16a2 Crank Pully, B16a2 Alternator, and B16a2 Intake Manifold (best flowing for the money, if not, If you've got money to spend, I'd go GSR or Type R, and any B-series VTEC Solenoid should work as far as I know.
Good luck on the build man! When you're done, post up your dyno numbers so we can compare!
-Rafe
-Rafe
i picked up a complete other b16 head and intake manifold today for 100 bucks with vtec solenoid, sensors, fuel rail, injectors the whole bit. also what are the best axels to use? thanks again
any B series oil pan will work as long as you get the corrosponding pickup tube.
any B series alt will work as long as it corrosponds to the OBD you plan to run (your harness).
any passenger side B series axle will work, drivers side depends on which intermediate shaft you use.
hope that helps.
hope that helps.
hope that helps.
hope that helps.
if im running an obd2 and obd2-obd1 harness with p28 obd1 ecu which alternator will i have to use?
DubyaAye
Sep 15, 2004 06:55 AM
