Need help, TACH problems
Old May 27, 2002 | 07:01 PM
Timmayeg's Avatar
New User
Default Need help, TACH problems
ok my stock tach is being really wierd, it is ok on low RPMs but when i get to higher rpms it goes all whack and starts bouncing around and ****, WTF? anyone have any ideas?
Old May 27, 2002 | 07:09 PM
djay86's Avatar
Default Re: Need help, TACH problems (B16aVtecCivic)
try cleaning your air filter
Old May 27, 2002 | 07:40 PM
fastwanabe's Avatar
sounds to me your igniter might be goin bad!!!
Old May 27, 2002 | 07:41 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: Need help, TACH problems (fastwanabe)
Old May 27, 2002 | 08:18 PM
DR. ON POINT's Avatar
Banned
Default Re: Need help, TACH problems (comptechgsr2000)
Fix Bouncing Tachometer.
Your tach bounces around, you get a misfire, and you get a code 15. Ok, the reason this is happening is because you are not getting a GOOD connection on your igniter. Those connections have to be TIGHT! Also, dielectric grease will help a TON! This is how you fix the problem.
Remove your distributor cap. If you still have the dist shield in place under the cap, then you will have to remove the rotor, and the shield. If your shield is already gone, you do not need to remove the rotor. When looking down onto the distributor, you will see the coil, the rotor, and some wires leading to a small, brown thing. This is the igniter. There will be 4 connections. 1 on the side, and 3 on top. Honda uses spade connectors to make these connections to the igniter. Remove, and work on only ONE CONNECTOR AT A TIME. Take each connector, and with it removed from the igniter, place it in the needle-nose pliers and crimp down a little tighter on the spade connector. Then put a dab of dielectric grease inside the spade connector. Then put the connector back on the igniter. The connection should be very tight. Do this with all the connections to the igniter. Replace the rotor (if you removed it) and then the cap. Then, under the fuse panel under the hood, remove the ECU and Hazard fuses for about 60 seconds. Replace both, and restart the car WITHOUT touching the gas. Let it run for 60 seconds without ANY accessories on. Then after 60 seconds, turn ALL the accessories on and let it run for 60 seconds. Turn the car off, restart it, and go have fun.
I was having this very same problem with my 92 GSR. After trial and error I found this to be the problem. I fixed it the first time without dielectric grease. The problem came back a few days later. I then redid the procedure and used dielectric grease. It has now been one month, no problems. Also, I did pick up a power gain as well.
Old May 27, 2002 | 08:34 PM
polymath's Avatar
Default Re: Need help, TACH problems (On Point EK!!!!!!!!)
what he said
Old May 27, 2002 | 09:18 PM
Timmayeg's Avatar
New User
thanks for the help guys, i just replaced the igniter so maybe there are some loose wires, all i know is its really pissing me off
Old May 30, 2002 | 11:10 PM
Timmayeg's Avatar
New User
Default Re: Need help, TACH problems (VTEC CX)
one point ek your the man, works fine now
Old May 31, 2002 | 05:03 AM
Banned
I know this man , glad I helped
usafhanda
Mar 14, 2012 10:29 PM
b18c5hatchie
Jul 2, 2004 06:59 PM
92HB_HB
Feb 25, 2004 06:52 AM
gsrvx
Jul 27, 2002 12:06 AM
customx_
Jun 18, 2002 11:30 PM
