Clunking noise
Old Apr 11, 2007 | 05:43 PM
JDM94HATCH's Avatar
Default Clunking noise
Whats up Fellas after searching and finding some things still no luck so hear is the deal
the snow fell pretty hard in jersey and after everything Iced over i had 2 move my car out of my freinds dry way into the street so i decided 2 park it on top of this BIG *** ice patch long story sort i got stuck on the ice patch as im trying 2 get out im sping out of the patch my front driver side wheel finally grabs some pavement.after my wheel hit's the street i get this wierd clunking nosie at take off after searching on H/T and T/I i changed my Axles and my outter tie rods after doing this i went to go c if the clunking noise went away so i take off and no clunking noise i drive down a couple main street's i pull into a wedey's i cut the wheel and i hear this clunking noise but this time its not as bad or loud i took the car home and i went to bed cause i was pretty beat the next moring i wake up and i decided to go take the car for an alighment so as im at the shop the owner is giving me **** cause my car is lowered so i get in the car pretty mad i start my car and took off pretty hard then the clunking noise came back idk what it is i changed my axels and my tie rod ends i hope i can get some help because ive been out of a car for a while now any help would be nice thanks
Old Apr 11, 2007 | 05:46 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Clunking noise (JDM94HATCH)
Could be control arm bushings - front or rear - could be swaybar endlinks - front or rear - could be trailing arm bushings - rear - could be failing engine mount - front - could be loose bolt in the suspension - front or rear.
Have you actually looked under the car yet or are you wasting my time? Also, give us a location to work with. A guess is better than nothing. Do you hear the bump or do you feel it in the floorboard or what? Does it make your car move when it happens? Does it happen when the suspension loads or unloads? Help us help you, killer
Old Apr 11, 2007 | 05:47 PM
TDSI99's Avatar
the noise could be the CV joints. You said it happens you are turning...sounds like CV joints to me. Give em a check out.
Old Apr 11, 2007 | 05:55 PM
JDM94HATCH's Avatar
no that only happend before i took off 2 hard now it clunks at take off and i changed my Axles allready and no luck .also my car has a b18a1 and i do not have have the torque mount's in i dk if that matters
Old Apr 11, 2007 | 06:12 PM
TDSI99's Avatar
I would think so. Try putting them in and see what happens
Old Apr 11, 2007 | 06:14 PM
JDM94HATCH's Avatar
Default Re: (TDSI99)
hahahah they are in allready man
Old Apr 12, 2007 | 09:02 AM
JDM94HATCH's Avatar
Default Re: (JDM94HATCH)
any1?!?!
Old Apr 12, 2007 | 10:11 AM
djsire's Avatar
i just went throught this.
it was my lca bushings.
pretty easty to fix yourself with hand tools.
Old Apr 12, 2007 | 03:07 PM
JDM94HATCH's Avatar
Default Re: (djsire)
iight thanks man ima gonna try that out and ill let u kno whats up
Old Apr 12, 2007 | 04:53 PM
djsire's Avatar
lift up the car. and try to pull the wheel from the bottom.
if it swings up a little its the bushing.
you will see where it moves.
its not suppose to
Old Apr 12, 2007 | 07:32 PM
JDM94HATCH's Avatar
ok guys after lifting up the car and trying what djsire said nd still nothing the only thing that u can c moving or hearing is the shock and i looked at both sides anything else guys??
Old Apr 14, 2007 | 03:55 PM
JDM94HATCH's Avatar
anybody?!?!
ramboPandA
Mar 23, 2015 08:41 AM
1freshEM1
Apr 9, 2010 07:27 AM
honda4674
Nov 1, 2005 07:40 AM
Supra
May 11, 2004 01:48 AM
Fooser
Jun 28, 2002 01:16 PM
