Stalling!!!!!!!!!!!!!!!
Old Apr 11, 2007 | 02:13 PM
ELSUICIDA's Avatar
Default Stalling!!!!!!!!!!!!!!!
hey my car was normal (d16y8) all of the sudden it starts to stall when im letting out the clutch, also when i change gears it gives me a a hard push againts the seat, what could cause this. Help please.
Old Apr 11, 2007 | 02:31 PM
Luserkid's Avatar
Default Re: Stalling!!!!!!!!!!!!!!! (ELSUICIDA)
New driver? <---- Serious question
Old Apr 11, 2007 | 02:33 PM
ELSUICIDA's Avatar
Default Re: Stalling!!!!!!!!!!!!!!! (Luserkid)
nah man!!!!!!!!!!l I know how to drive stick
chadalac1712's Avatar
solds like your dumping the clutch really fast
Old Apr 11, 2007 | 02:54 PM
97Ej6mike's Avatar
Could Be your Throttle Position Sensor if your claiming if feels like sudden jerking. If thats not working correctly, when you gas the pedal, even just a tiny bit, it will rev like you have put it to the floor.
As for the Stalling, seems like you need to have your Idle Adjusted higher.
Now Ive had issues in the past where the TPS hasnt been correctly installed, and when you gas it, it will cause the motor to jerk somewhat violently when given a little gas, and you feel this more when your changing gears, when you arent so heavy on the gas pedal (assuming your driving normal)
Elaborate on the problem some more, are you getting any Check engine codes?
Old Apr 11, 2007 | 03:20 PM
Luserkid's Avatar
Default Re: (97Ej6mike)
I like how the TPS started to become the worst enemy in the honda world. Unless you touched the TPS it should never give you a problem.
Try bleeding your clutch, could be that airs in the lines and its causing a false reading. Also look around your clutch pedal and see if theres any leaks, and finally check your fluid levels.
Old Apr 11, 2007 | 05:27 PM
ELSUICIDA's Avatar
Default Re: (Luserkid)
hey thanks for the feedback, but i have never touched my tps or map im just thinking it could be a dirty fuel filter (clogged), or maybe even my spark plugs.
Old Apr 11, 2007 | 05:58 PM
BADHDRIVER's Avatar
Default Re: (ELSUICIDA)
engine picture pls...
Old Apr 11, 2007 | 06:39 PM
97Ej6mike's Avatar
Replace fuel filter and put in some brand new plugs.. Reset the ECU, and see where that gets ya.
bigred850
Engine Management and Tuning
Sep 24, 2011 03:31 PM
adidas333
19
Jun 2, 2009 08:01 PM
jds62f
Feb 28, 2006 06:14 PM
95vtec
Feb 14, 2002 05:31 PM
