Swapping a 94 integra LS (manual) into a 99 civic EX (automatic)
So I am swapping it in and wanted to know if I will need aftermarket motor mounts in order to do this. Also Will the axles from the integra work on my EX? Any problems or issues that you know of with the auto to manual conversion, please let me know. Thanks in advance.
c mon guys? somones got to have some helpfull info....i found the mounts that i need and now i just need some info for the auto to manual and the axles
EK auto to manual w/ B series, obviously you need flywheel{b series}, clutch{b series}, flywheel bolts{b series}, these are all EK parts following : 5speed pedal assembly, clutch master, slave cylinder, hydro lines for the firewall, a 99-00 civic Si rear engine bracket, and 99-00 Civic Si motor mounts or hasport {EKstk kit}, EKB series linkage from Hasport or 99-00 Si linkage with shifter and all bushing as well as mounting bolts, theres some starters to get the motor in there. There will be some wiring differences also. http://www.hasport.com in the instruction section takes care of a lot of it. My boys at Tokyo.Speed.Pros in AZ can help too if you like Im sure they be happy to help. their email is gofast@tokyospeedpros.com or 480-539-5653
i have the whole integra, i cant use the pedal assembly from there?? soo i need all ek pedals and lines?? and i cant use the integra ones?
New tech
Jan 29, 2015 05:57 PM
Jhicks
14
Apr 25, 2012 09:00 AM
