new car help
Old Apr 11, 2007 | 12:23 PM
stock99si's Avatar
Default new car help
hey guys i need some help, i have civic 99 si(b16a2) with a thermal exhaust and a k&n intake (came with the car). its got stock suspension, but new rims and tires. and shortshifter
what should my next step be to modifying the car, i mainly want speed, and good for dragging, please give me some tips, nothign too pricy please. thank you
Old Apr 11, 2007 | 12:28 PM
heff's Avatar
Default Re: new car help (stock99si)
work on security first before modding out your car.
Old Apr 11, 2007 | 12:41 PM
blk_EK's Avatar
Default Re: new car help (heff)
depends on your price range. If you want performance your gonna have to spend well over $100 to get some results.
The first thing I got on my civic was sercurity
Old Apr 11, 2007 | 12:50 PM
stock99si's Avatar
Default Re: new car help (blk_EK)
yea i could get something over 100 bucks but just not 2 much over, and i want results.
and yea im getting viper alarm
Old Apr 11, 2007 | 01:22 PM
FastLife617's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heff &raquo;</TD></TR><TR><TD CLASS="quote">work on security first before modding out your car.</TD></TR></TABLE>
yeah first do that get a good alarm system and add some kill switches b.c EM1 attract alot of thief's . . . but if u want speed with ur B16a2 i recommend go with Boost
Old Apr 11, 2007 | 01:29 PM
stock99si's Avatar
Default Re: new car help (FastLife617)
can u jsut explain how much a kill switch cost? and what exactly it does
and im lookin for something other than boosting
Old Apr 11, 2007 | 01:34 PM
https://honda-tech.com/zerothread?id=1794938 check this link out its very helpful it will explain it all too you . . . also how much are you trying to spend on the motor??
Old Apr 11, 2007 | 01:37 PM
punoy69's Avatar
boost lol
Old Apr 11, 2007 | 01:53 PM
stock99si's Avatar
around 200 something like that maybe 300
Old Apr 11, 2007 | 01:57 PM
To get power out of a B16a2 u need alot more then that but with that range you could get your self a nice air intake or order a cheap one from ebay and throw a K&N filter on it. . and spend the rest on maintenance on the engine if u havent done that already . . .
Old Apr 11, 2007 | 01:59 PM
stock99si's Avatar
come onn lol, b16's cant be that bad, i find it pretty quick.
what u mean by matinenance, i did oil change. iono if i should do tranny flush?
punoy69's Avatar
save up and buy these : :
Old Apr 11, 2007 | 02:03 PM
no i didnt say they bad at all i love mine i my self got a 00 civic si is just that B16a2 the best way and the most affordable way to get power out of them is boost IMO but if your happy with it as it is save up some money and do ur suspension
Old Apr 11, 2007 | 02:06 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock99si &raquo;</TD></TR><TR><TD CLASS="quote">come onn lol, b16's cant be that bad, i find it pretty quick.
what u mean by matinenance, i did oil change. iono if i should do tranny flush?</TD></TR></TABLE>
Yeah, actually, they can be that bad Your car runs nothing better than a mid-15, and another $200-$300 is not going to improve that (unless you can find a used nitrous setup for that much).
You need forced induction or more displacement. Pick your poison and start saving.
Old Apr 11, 2007 | 02:38 PM
big-cat's Avatar
to go faster your choices are boost, n02, supercharger, and the really expensive route would be to go naturally aspirated and you will make alright Hp but not as much as boost or anything else for that matter and spend mucho more amount of money.
if i were you i would get some suspension instead.
Old Apr 11, 2007 | 02:44 PM
94c1v1cex's Avatar
they pull about the same as d16 until around 5k i think... so unless you're running over that (which i suspect you are) its about the same as a d16
so ya it is that bad
when i blow my d16... i say when cause it will happen... i'm gonna get b18 or b20 for sure
Old Apr 11, 2007 | 03:36 PM
blueb16's Avatar
Default Re: new car help (94c1v1cex)
yah boost is the way to go.im going for boost also...
Old Apr 11, 2007 | 03:38 PM
stock99si's Avatar
yea dude after 5 k i think its a beast for a 4 cylinder 1.6 liter, no other like it.
but im just scared of blowing my engine with turbo, how muchpsi could i run a turbo with stock internals without blowing anything even if i beat on the car?
Old Apr 11, 2007 | 03:50 PM
JKov240's Avatar
It's all in the tune to make a turbo car reliable...but if it were MY car with stock internals, I wouldn't go over 8psi.
You're going to have to spend some money if you want it to run decent, and the best HP per dollar is spent on a turbo kit IMO
Old Apr 11, 2007 | 05:26 PM
Silvertc's Avatar
Default Re: new car help (JKov240)
i would go with suspension
Old Apr 11, 2007 | 05:44 PM
TDSI99's Avatar
8psi is a good starting point. Go with boost and suspension.
Old Apr 11, 2007 | 05:55 PM
BADHDRIVER's Avatar
Default Re: (TDSI99)
94 octane gas..
Old Apr 11, 2007 | 06:03 PM
Felliph3's Avatar
Default Re: (BADHDRIVER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BADHDRIVER &raquo;</TD></TR><TR><TD CLASS="quote">94 octane gas.. </TD></TR></TABLE>
BLAHHAHAHAHAHHAHHAH!!!!
First off noob,94 octane gas on a stock b16 will make it loose power.
Secondly the higher the octance does not mean higher the hp.It simply measures its probability to knock or in other words,how conbustible it is. You see race cars using high octane fuel and that is because they either have a high compression motor which the fuel self ignites before it reaches TDC(top dead center) or they have a turbo setup.When air is compressed,its temperature reaches and in a turbo engine where there is a lot of compressed air,it has enough activation energy to ignite the fuel where its supposed to be done by spark plug.
Old Apr 11, 2007 | 06:17 PM
stock99si's Avatar
Default Re: (Felliph3)
how much horespower woudl i get out of like 5 psi, i wanna do 5 psi just to stay on the safe side cuz i wanna keep this car for a while.
Old Apr 11, 2007 | 07:43 PM
ke98248's Avatar
Default Re: (stock99si)
probably low 200's, are you talking about WHP or just HP?
