16x7 slips with Kumho ECSTA SPT for my DD/possibly autox
Old Apr 11, 2007 | 11:47 AM
pjr710's Avatar
Default 16x7 slips with Kumho ECSTA SPT for my DD/possibly autox
right now this combo seems like its the best option for me to get, my car will be daily driven, and i've never tried autox, so i might try this summer possibly, will these do the trick?
these will only be summer tires, and if you guys have any recommendations let me know
these just seem to be a good price, and people say good things about them
Old Apr 11, 2007 | 12:13 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 16x7 slips with Kumho ECSTA SPT for my DD/possibly autox (pjr710)
I assume you will be getting the tires in size 205/45-16 for your '97 Civic.
Excellent choice!
Old Apr 11, 2007 | 12:16 PM
pjr710's Avatar
Default Re: 16x7 slips with Kumho ECSTA SPT for my DD/possibly autox (nsxtasy)
205/40/16 .. do you still approve?
Old Apr 11, 2007 | 02:34 PM
JustinHoMi's Avatar
The 205/40 will give you closer gearing and better acceleration, but won't be quite as wide. It might look a bit funny though if the car hasn't been lowered, since it's lower profile.
The SPT's are excellent in the rain, and pretty grippy overall. They won't be super competitive on the autox course, but still decent.
Old Apr 11, 2007 | 02:42 PM
pjr710's Avatar
Default Re: 16x7 slips with Kumho ECSTA SPT for my DD/possibly autox (JustinHoMi)
yea i plan to lower my car pretty low, so the 40's should look nice, although the 45's are $40 cheaper, but i like the look of the 40's better
i keep hearing good things about these spt's i'm very happy about that, and as for the autox, i've never done anything like it so i just need these to be ok, i'm not serious about it ....... yet
Old Apr 11, 2007 | 08:08 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pjr710 &raquo;</TD></TR><TR><TD CLASS="quote">yea i plan to lower my car pretty low, so the 40's should look nice, although the 45's are $40 cheaper, but i like the look of the 40's better
i keep hearing good things about these spt's i'm very happy about that, and as for the autox, i've never done anything like it so i just need these to be ok, i'm not serious about it ....... yet </TD></TR></TABLE>
Don't buy tire sizes for looks, buy the correct size to keep the speedometer and odometer accurate. Now, if the tires were only used for auto-x, then thats a different story.
And SPTs will be fine for autox. I started off on the stock Michelin XGT V4s(much much worse then SPTs), and they held up fine for a couple of events, until a practice got them hot enough to start melting the tread blocks together (my fault for not cooling them adequately). Just don't keep running them lap after lap during a summer practice without cooling them.
Old Apr 11, 2007 | 08:10 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 16x7 slips with Kumho ECSTA SPT for my DD/possibly autox (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">Don't buy tire sizes for looks, buy the correct size to keep the speedometer and odometer accurate.</TD></TR></TABLE>
The correct size for your car is 205/45-16. Buy the correct size.
Old Apr 11, 2007 | 08:12 PM
pjr710's Avatar
why is it the correct size? .. and what advantagess to i get with 45'd
Old Apr 11, 2007 | 08:35 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pjr710 &raquo;</TD></TR><TR><TD CLASS="quote">why is it the correct size? .. and what advantagess to i get with 45'd</TD></TR></TABLE>
It's the correct size because the outer diameter is about the same (within 1 percent) of the outer diameter of your stock tire size, so it will maintain the accuracy of your speedometer and odometer. 205/40-16 is too small (over 4 percent smaller than stock, a full inch, which is a big difference) so it will throw off the gauges. It will also look rather silly. (The 205/40-16 is the much smaller size that fits older Civics that came with 13" wheels.) And, as you mentioned, the correct size for your car is $65/tire, and the too-small 205/40-16 is $77/tire, so a set of the wrong size tires costs $48 more than a set of the correct size for your car. So there are a whole lot of advantages of getting the correct size, without any significant disadvantages.
Look at the calculated outer diameters for yourself:
185/65-14 - 23.47 inches (stock)
205/45-16 - 23.26 inches (-0.9 percent)
205/40-16 - 22.46 inches (-4.3 percent)
Old Apr 11, 2007 | 09:10 PM
pjr710's Avatar
hmm thats interesting .. i just thought the 40's look better because it makes the wheels look a bit bigger, the 45 shows a lot of tire ..
im curious as to how the 40 is "much smaller", i thought 205/45 and 205/40 are both the same width just with different sized sidewalls .. am i wrong about this?
Old Apr 12, 2007 | 05:23 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pjr710 &raquo;</TD></TR><TR><TD CLASS="quote">im curious as to how the 40 is "much smaller", i thought 205/45 and 205/40 are both the same width just with different sized sidewalls .. am i wrong about this?</TD></TR></TABLE>
You are correct; the tread is the same width. The sidewall is taller with the 205/45 (since it's equal to .45 * 205 mm instead of .40 * 205 mm). That's why the outer diameter of the 205/45 is larger than the 205/40.
For your car, just get the 205/45-16.
Old Apr 12, 2007 | 06:33 AM
JustinHoMi's Avatar
That's probably incorrect... most likely they are going to have different treadwidths, but I can't find the exact specs anywhere.
Old Apr 12, 2007 | 07:47 AM
pjr710's Avatar
nxnasty i must say.. i had absolutely no intentions of buying the 45, but after you saying this stuff, and after doing some searching of pictures between 40's and 45's and hearing people say how much more they like their 45's .. i think im going to go with them ... so thanks man
Old Apr 12, 2007 | 02:07 PM
DaveSi677's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustinHoMi &raquo;</TD></TR><TR><TD CLASS="quote">That's probably incorrect... most likely they are going to have different treadwidths, but I can't find the exact specs anywhere.</TD></TR></TABLE>
How can a 205 width be different from another 205 width of the same brand tire? If you are talking about a 205 SPT vs a 205 RT615 then I could see the RT615 being a bit bigger.
To the OP, I have alot of experience when it comes to tires but compared to Nsxtasy, I am noob! Don't be a idiot and think you know what you are talking about because let's face ityou don't. So get the right size for you car and not the one that looks cool! You will thank us later! Also I have the SPT's and I am really happy with them. For auto-x they will do fine in the beginning as you are learning but after you might want to get something a little more sticky.
Old Apr 12, 2007 | 04:47 PM
pjr710's Avatar
Default Re: 16x7 slips with Kumho ECSTA SPT for my DD/possibly autox (DaveSi677)
i'm gunna get the 45's .. but just out of curiosty .. 16's with 45's are w/in an inch of original wheel size what would 17's and 40's be?
Old Apr 17, 2007 | 06:29 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pjr710 &raquo;</TD></TR><TR><TD CLASS="quote">i'm gunna get the 45's .. but just out of curiosty .. 16's with 45's are w/in an inch of original wheel size what would 17's and 40's be?</TD></TR></TABLE>
205/40-17 is fine for your car. It has exactly the same outer diameter - 23.46 inches - as your stock size.
Scotty Dosent Know
Mar 24, 2013 09:40 AM
icucnme
Apr 5, 2010 09:06 AM
Jvs10
Mar 30, 2010 07:32 AM
kulo
Jan 22, 2009 07:36 PM
Dan GSR
Sep 16, 2002 12:01 PM
