lowering springs
Old Apr 11, 2007 | 10:22 AM
streetcartuner's Avatar
Default lowering springs
when buying lowering springs what a good drop
because i have coilovers and im going through tires so fast 2 pair in under 6 months
so i want to do lowerings springs and i want a nice drop but not to much to the point were im going through tires like a bitch so
im wondering if a 2 inch drop would still be safe still its for a 93 hatchback
Old Apr 11, 2007 | 10:24 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: lowering springs (streetcartuner)
If ride height is your only problem, why not just raise the coilovers?
did you ever get an alignment after you put on your coilovers?
Old Apr 11, 2007 | 10:33 AM
Default Re: lowering springs (SkoundrelUSA)
no i didnt get aliment after but i had it drop like hard core like to the max and i went through so many tires and not to much a fan of the very stiff springs
Old Apr 11, 2007 | 10:46 AM
95jeremie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetcartuner &raquo;</TD></TR><TR><TD CLASS="quote">when buying lowering springs what a good drop
im wondering if a 2 inch drop would still be safe still its for a 93 hatchback</TD></TR></TABLE>
get a camber kit it will save your tires and give you the ride that your looking for
i have skunk 2 camber kit, drop zone coilovers, kyb gas shocks
Old Apr 11, 2007 | 10:57 AM
instructor74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetcartuner &raquo;</TD></TR><TR><TD CLASS="quote">no i didnt get aliment after but i had it drop like hard core like to the max and i went through so many tires and not to much a fan of the very stiff springs
Well then GET THE CAR ALIGNED. When you drop a car even 2 inch's it changes the toe and the camber settings. The toe setting being off will really eat your tires then add in the camber being out of whack also and you will be going through tires like you have been.
Old Apr 11, 2007 | 11:05 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: lowering springs (instructor74)
Camber won't make that big of a deal. You need to get it aligned and tell them to zero the toe.
You'd have to be dropped like 4" for camber to make a big difference in tire wear.
it's your toe maing.
Old Apr 11, 2007 | 11:47 AM
bbbleondacomeup's Avatar
Default Re: lowering springs (ek forever guy)
changing from coilovers to springs wont make a difference in ur tire wear
Old Apr 11, 2007 | 01:17 PM
HXvtec's Avatar
Default Re: lowering springs (bbbleondacomeup)
camber kit and your set. also you should prob raise it
Old Apr 11, 2007 | 01:30 PM
punoy69's Avatar
Default Re: lowering springs (HXvtec)
TOE TOE TOE TOE
get an alignment and you should be set, the toe is what eats your tires, camber has little effect, if you need more help, head to the suspension forum and look for Tyson or someone else
Old Apr 17, 2007 | 10:16 AM
Default Re: lowering springs (punoy69)
ya but im wondering if 2 "s will be good drop with out getting camber or toe
Old Apr 17, 2007 | 08:46 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetcartuner &raquo;</TD></TR><TR><TD CLASS="quote">ya but im wondering if 2 "s will be good drop with out getting camber or toe </TD></TR></TABLE>
Even with a 2.5" drop camber won't effect tire wear.
Lowering your car AT ALL can expletive up your toe. Having a tire leaning sideways is a lot better than tires like this \ /
Old Apr 18, 2007 | 07:39 AM
2coupes's Avatar
http://heeltoeauto.com/httech/...87420
shelbyEK!
Suspension & Brakes
Sep 17, 2009 08:57 AM
ZOMBIEKILLER
Mar 3, 2008 03:23 PM
02whiteDC5
Jul 30, 2007 02:24 PM
Exploder39
May 18, 2007 09:08 AM
Skandlss
Mar 14, 2004 07:24 PM
