H22 into eg wiring harness
Old Apr 11, 2007 | 07:32 AM
92jdmh22eg's Avatar
Default H22 into eg wiring harness
I am installing an h22a fully built into my eg hatch and i wanted to know which harness i should use to break apart to make it larger
thanks
Old Apr 13, 2007 | 11:16 PM
dannis.'s Avatar
Default Re: H22 into eg wiring harness (92jdmh22eg)
just use a 95 gsr harness and extend the alternator wires. hell it even works with a y8/z6 harness.
Old Apr 14, 2007 | 06:10 AM
big-cat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92jdmh22eg &raquo;</TD></TR><TR><TD CLASS="quote">I am installing an h22a fully built into my eg hatch and i wanted to know which harness i should use to break apart to make it larger
thanks</TD></TR></TABLE>
you should use a stock h22a harness. thats why they made the h22a harness, so it would hook up to h22a's lol. if you use another type of harness it is going to be a pain in the ace.
Old Apr 14, 2007 | 09:45 AM
CivicSpoon's Avatar
Default Re: H22 into eg wiring harness (big-cat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big-cat &raquo;</TD></TR><TR><TD CLASS="quote">you should use a stock h22a harness. thats why they made the h22a harness, so it would hook up to h22a's lol. if you use another type of harness it is going to be a pain in the ace.</TD></TR></TABLE>
No it won't. There are only a few wires that need to be added, the rest is plug and play.
Old Apr 14, 2007 | 09:53 PM
dannis.'s Avatar
the problem there is that the stock h22 harness doesnt work with an eg. therefor he need to use a gsr, b16, or a y8/z6 harness.
Old Apr 15, 2007 | 03:49 PM
big-cat's Avatar
Default Re: H22 into eg wiring harness (DannisEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DannisEG6 &raquo;</TD></TR><TR><TD CLASS="quote">
the problem there is that the stock h22 harness doesnt work with an eg. therefor he need to use a gsr, b16, or a y8/z6 harness.</TD></TR></TABLE>
cant you just use the h22a ecu and have it plug right into the harness as well as the engine. how will that not work.
either or dood, it sounds like you will have little problems your going to have to deal with what everyone is saying your going to have to modify a b-series harness. idk but good luck with what ever you do.
Old Apr 16, 2007 | 10:49 AM
LSR 0NE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DannisEG6 &raquo;</TD></TR><TR><TD CLASS="quote">just use a 95 gsr harness and extend the alternator wires. hell it even works with a y8/z6 harness.</TD></TR></TABLE>
Ok what about the injectors, I thought they need that resister box(or somthing) to work.
Old Apr 17, 2007 | 03:41 PM
CivicSpoon's Avatar
Default Re: H22 into eg wiring harness (LSR 0NE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSR 0NE &raquo;</TD></TR><TR><TD CLASS="quote">Ok what about the injectors, I thought they need that resister box(or somthing) to work.</TD></TR></TABLE>
That is correct.
230 cougar
Jul 27, 2009 10:55 PM
Sick EM1
Sep 10, 2007 05:43 PM
aznevanchoi
Mar 1, 2007 08:00 AM
SCRATCH
Jan 30, 2007 01:38 PM
