how do I wire up a second o2 sensor to the ecu
I got a 96 Honda Civic Cx hatch. Im using a 98 Honda Civic Ex Wire harness. It only has one a plug for the primary O2 sensor. Im trying to figure out the easy way to wire the second O2 sensor up. I using a 98 gsr ecu.
What does each wire on the o2 sensor stand for and where on the ecu should I tap it in to.
Green -
White -
Black -
Black -
Green -
White -
Black -
Black -
well the 98 gsr computer is OBD2 so it has to be pre wired to accept a secondary o2 obviously, and your car is an obd2 car. So you should have the plug there, and everything should be plug and play if you have and OBD2a to OBD2b conversion harness.
HondaFerris
Aug 5, 2014 09:05 AM
EX-T
12
May 24, 2008 08:01 PM
