My GE lsvtec dowel pins are loose in the block...Are yours???
Old Apr 11, 2007 | 02:41 AM
haveaNOSday's Avatar
Default My GE lsvtec dowel pins are loose in the block...Are yours???
I'm ready to install my PR3-2 head onto my B18A1 and the damn GE pins are loose in the block!! I read this being a problem somewhere on here but I can't remember which thread and page, if someone knows please link me up. Anyways now I'm concerned if this is going to be the cause of an coolant or oil leak? I wonder if there's a fix for this because I don't want to wait another month the receive new pins!!! Any suggestions??? I'm thinking hondabond but I would like to avoid it if possible.
Old Apr 11, 2007 | 07:23 AM
gibsanez's Avatar
Default Re: My GE lsvtec dowel pins are loose in the block...Are yours??? (haveaNOSday)
One is loose and the other i had to hammer in....all they do is align the head, they don't seal anything.
Old Apr 11, 2007 | 07:42 AM
NJcoupe's Avatar
Default Re: My GE lsvtec dowel pins are loose in the block...Are yours??? (gibsanez)
Mine slipped right in; they werent too loose; but they work perfectly fine vs. the off brand ones i had
Old Apr 11, 2007 | 07:51 AM
Jay_Sensing's Avatar
Mine were farely loose when they went in the first time, pretty much slid in. Once the head was tq'd though they became pretty solid.
Last time I had the head off the car, I came to the conclusion when I have to remove then eventually, it's going to require a drill and a torch
Old Apr 12, 2007 | 02:49 AM
Default Re: (Jay_Sensing)
dude you really went 12.9 with your lsvtec!!! I know this set up goes good but damn...my friend went 12.8's in his SC S2000.
Old Apr 12, 2007 | 03:15 AM
Yeah, and that was on a street tune and 2.25 exhuast.
12.90's aren't impressive. Look around the rest of this board and see what a lot of guys are running with lsvtecs.
Old Apr 12, 2007 | 06:17 AM
mar778c's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay_Sensing &raquo;</TD></TR><TR><TD CLASS="quote">12.90's aren't impressive.</TD></TR></TABLE>
Damn, how fast do you need to go before it is impressive, lol.
Seriously, 12.9 is a all motor civic is pretty good.
Maybe, I'm easily impressed but that is a very respectable number.
Old Apr 12, 2007 | 06:20 AM
11.90's
My setup won't see that on motor but should see deeper in the 12's. Hopefully close to the 12.40 range. Getting the car on the dyno tonight to get it a bit more aggresively tuned and see what I can do Sat night.
Old Apr 12, 2007 | 10:12 AM
EGhatch87's Avatar
mine were loose on the block but tight on the head...anyway they dont seal anything there just for you can line up the head on the block when installing
Old Apr 13, 2007 | 02:36 AM
yeah so far statisticly from my researching and installing the head my pins are loose in the block and tight in the head aswell. I also had to sand the inside of the pin to pass throught the head stud It was a bit rough and I didn't like that.
Raptastik87
Jan 21, 2008 05:38 PM
teggy_94LS
Oct 1, 2007 06:44 PM
shifts
Apr 5, 2007 07:26 AM
oranginal
Oct 16, 2006 09:59 AM
KooK
May 30, 2003 09:27 AM
