Weird thumping sound when wheel is cranked a few degrees to the right
Old Apr 10, 2007 | 11:47 PM
preludedriva's Avatar
Default Weird thumping sound when wheel is cranked a few degrees to the right
b16 with b16 tranny
think it just started happening
im not entirely sure i was driving on the freeway with my music off just to hear my car and i noticed this noise
and its only when my steering wheel is slightly turned a few degrees to the right
any idea what it could be?
it doesnt do it on hard rights or lefts so im pretty sure its not the axles....plus i replaced my driver side on a lil bit ago
edit: lug nuts are tight too just checked
Old Apr 11, 2007 | 10:15 AM
Default Re: Weird thumping sound when wheel is cranked a few degrees to the right (preludedriva)
anyone?
Old Apr 11, 2007 | 11:12 AM
tpr's Avatar
tpr
Check the steering rack mount. It will sometimes "thump" if loose.
Old Apr 12, 2007 | 01:43 PM
Default Re: Weird thumping sound when wheel is cranked a few degrees to the right (tpr)
ill do that i have no idea where its located but i will take a look
it never thumps when i crank it more then a couple of degrees (example full turn)
i raised up the car and took off the rims and checked all of the suspension everything seems in order
i will check that steering rack mount though
thanks
Old Apr 16, 2007 | 05:02 AM
i tightened both 14mm and 17mm bolts in the steering mount and it still does it
anything else it could be?
Old Apr 16, 2007 | 05:07 AM
THC07's Avatar
Default Re: (preludedriva)
wheel bearing dude... take off the hub/nuckle. buy the bearing from kregans, cuz they price match. i got mine for 50$ and have a machinest press it back into the hub. good luck
Old Apr 16, 2007 | 10:59 AM
Default Re: (THC07)
damnit i was hoping it wouldnt be a bearing
which side would it be?
Old Apr 16, 2007 | 01:48 PM
THC07's Avatar
i dunno, jack up one wheel at a time and try to see which is making noise or wiggles.
Old Apr 16, 2007 | 09:24 PM
anything else it could be? its whenever i turn to the right slightly
Old Apr 16, 2007 | 10:23 PM
beav's Avatar
could also be a ball joint about to go bad.
Old Apr 17, 2007 | 06:19 AM
THC07's Avatar
A really really really bad axle
Old Apr 17, 2007 | 07:08 AM
HONDURA2K2's Avatar
could also be the strut mount bearing
Old Apr 17, 2007 | 10:01 AM
beav's Avatar
Default Re: (HONDURA2K2)
yeah....noises suck man.
they drive me nuts!
good luck though.
Old Apr 17, 2007 | 01:17 PM
Default Re: (THC07)
i checked the axles my driver side is new and the passanger doesnt have a tear in it at all
Old Apr 17, 2007 | 01:23 PM
THC07's Avatar
dosent have to be twron to be bad, did you shake and pull on things to see if anything was lose?
hows the rubber around the ball joints and tie rods?
Old Apr 17, 2007 | 02:49 PM
Default Re: (THC07)
my friend is gonna take a look at it tommorrow see whats goin on bout it
ill check the tie rods and ball joints too
ive got another hub assembly so if it is the wheel bearing its no prob
Bleakened
Nov 24, 2017 05:58 AM
4tika4
Aug 15, 2016 09:10 PM
Love2redline
May 13, 2009 06:16 PM
Demonis
Honda Civic (2006 - 2015)
Dec 9, 2006 12:56 PM
JoshRambo
Nov 1, 2002 01:30 PM
