having gsr doubts
Old Apr 10, 2007 | 09:39 PM
novtecnoboost's Avatar
Default b18c1 problems
yo so i raced these two civics on sunday
it was crazy how bad i kept up but it didnt matter
Modified by theb18c1 at 5:52 PM 4/11/2007
Old Apr 10, 2007 | 09:41 PM
Luserkid's Avatar
Default Re: having gsr doubts (theb18c1)
Any codes? What was your 60ft? Might be your driving. Also I think those other hatches had more then a stock single cam.
Old Apr 10, 2007 | 09:48 PM
i have a check engine light for a o2 sensor not working and misfire and crankshaft speed sensor
Old Apr 10, 2007 | 09:49 PM
Boostedb20EH2's Avatar
Compression and leakdown test..?
Old Apr 10, 2007 | 09:57 PM
skUnK2jdm's Avatar
Default Re: having gsr doubts (Boostedb20EH2)
the other hatchs you raced were probably spraying! you should get some 4 into 1 headers 2 and 3/4 pipe, and is your ecu chipped?
Luserkid's Avatar
Yea sounds like your motor isnt in best of shapes now. If you want you could bring you car by and ill take a look at it. Im 10 mins from East LA. PM me if interested.
Old Apr 10, 2007 | 09:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">no not yet i have yet to find a good mechanic shop in my area.well some one honest at least. the guy who did my swap talked big and bad but didn't know what the hell a bent valve was. or why my fan wasn't turning on.
and sold me a chipped gsr ecu for 200 bucks.
and now i get literally 8-10 mpg.</TD></TR></TABLE>
Thats probably your problem..
Old Apr 10, 2007 | 10:03 PM
ok so what should i be worried about
spendin 3 g's
or just getting the little stuff done and see how it works out
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: having gsr doubts (skUnK2jdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skUnK2jdm &raquo;</TD></TR><TR><TD CLASS="quote">the other hatchs you raced were probably spraying! you should get some 4 into 1 headers 2 and 3/4 pipe, and is your ecu chipped?</TD></TR></TABLE>
what are you talking about?
to the OP, if your trans is that bad, think about how the guy was driving the car. The engine is probably pretty beat up. I'd do some compression/leakdown numbers on it. Put in a stock ECU. The guy probably sold you some wack program. You should, by no means get beat up on by a D-series. Unless they're super modded. I'm not only saying that because i dispise D series motors...but..thats some of the reason. Anyway, it's probably running WAYYYY to freaking rich with the ecu program. Plus if your 02 sensor is throwing a code, then ....that would kinda explain your 8-10mpg (coupled with the ecu you have). Your misfire sensor code is another bad thing to have. Is the misfire sensor not plugged in or is it broken? IS THE CAR MISFIRING? lol stupid question, but still.
OORRRR you just cant drive
Old Apr 10, 2007 | 10:07 PM
Default Re: having gsr doubts (B serious)
i dont here it misfire it runs good and feels strong.
the shop told me i only needed one o2 sensor then i went back and now he says i need 2.
but i dont have another bung or harness to put it in.
i already replaced the o2 sensor.
um another thing when i am at a coast like driving down a hill and letting it roll about 40
my car rpms dont drop.
they drop when i put it in nuetral. then shoot back up to about 1.5 to 2k rpms then when i stop it goes down to 6-700 rpm
is that the tps sensor.
Old Apr 10, 2007 | 10:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
This is what i was thinking,its probably something he got off ebay.. I dont really trust what your saying is a "chipped ecu".
Old Apr 10, 2007 | 10:11 PM
na i bought the ecu from the shop.
Old Apr 10, 2007 | 10:12 PM
What is it "chipped" for?
Old Apr 10, 2007 | 10:13 PM
he said he used the ecu to run all his motors.
when i first took it home i had no 02 sensor and it still engaged in to vtec.
the guy i bought the swap from screwed me
bad tranny
obd1 ecu
bad axels(threads where stripped)
overheated.(thermostat was stuck)
and tranny had no vin
Old Apr 10, 2007 | 10:14 PM
guttedEF's Avatar
Is VTEC even engaging with those CEL codes on? Especially the misfire one, I doubt it's engaging.
I say you take "Luserkid" up on his offer to let e fellow HT member help you out. Could be something as small as a losse ignition wire, could be serious. I definetely wouldn't be out racing and driving it hard with codes though.
Good luck..
Old Apr 10, 2007 | 10:15 PM
Default Re: (guttedEF)
no the VTEC is working i could tell the diffrence
Old Apr 10, 2007 | 10:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">obd1 ecu
Put this in your good list rather than bad.
guttedEF's Avatar
This could be an issue too. Do a compression test, that's an easy way to check for possibly damage. If you don't have a gauge you can rent one from AutoZone.
Old Apr 10, 2007 | 10:17 PM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">he said he used the ecu to run all his motors.
bad tranny
obd1 ecu
and tranny had no vin</TD></TR></TABLE>
-His motors all ran like **** or he lied.
-The 02 sensor has nothing to do with VTEC. It does, however have something to do with partial throttle cruise and GAS MILEAGE.
-Yes he did.
-Yeah...that kinda sucks.
-OBD1 ECU does not look for misfire sensor. So...
-axles &lt;~~~is spelled like that. Also have nothing to do with speed...but the overall crappy condition of the swap.
-He probably stole it.
Sorry you got screwed. How much did you pay?
Old Apr 10, 2007 | 10:21 PM
2 thousand.
well the thing with the ecu i thought everything was for an obd2
since the motor was form a 97.
then i even told him my car year and everything and he said it would be finr.
so when i got to the shop thats when i found out.
Old Apr 10, 2007 | 10:23 PM
guttedEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">2 thousand.
so when i got to the shop thats when i found out.</TD></TR></TABLE>
It's safe to say that someone is jacking you around here. Either the guy who sold you the swap, the shop you're going to, or possibly both of them. I saw go pay "Luserkid" a visit. I don't know him personally but I've seen his posts and he seams to know what's up..
I hate to see people getting taken advantage of.
Old Apr 10, 2007 | 10:24 PM
Default Re: having gsr doubts (guttedEF)
guttedEF's Avatar
Keep us posted as to how it turns out.. Good Luck..
Old Apr 10, 2007 | 10:26 PM
alright i am going to check out what luserkid thinks
Old Apr 10, 2007 | 10:27 PM
Default Re: (theb18c1)
thanks everyone for helping out so quickly.
now i remember why i like this site so much
