not just another D series oem tranny build
Has anyone pondered this build??
After pondering all day about how to build a replica ITR s80 gearset without swaping from my stock 4.25 final drive this is what I came up with....
It is very similar to bense's batman trans found here :http://bensebuilt.livejournal.com/2006/11/11/
The limiting factor is the tall second gear of the zc @ 1.944 but its as good as you will get with the 4.25 FD
This Is what I came up with*(all with 205-50-15's)
1st - 3.250 si/hf/ex/zc/lx/dx... 1st
2nd - 1.944 zc 2nd
3rd - 1.650 hf 2nd
4th - 1.259 si/ex 3rd
5th - 0.937 cable si 4th (but may go with zc 5th (.878) or cable si 5th (.771))
FD - 4.25 si/ex
mph with 8000 redline
1st - 39.77
2nd - 66.48
3rd - 78.33
4th - 102.66
5th - 137.93 (or with zc 5th 147.2)(or cable si 5th 167.63)
mph with 9000 redline
1st - 44.74
2nd - 74.79
3rd - 88.12
4th - 115.49
5th - 155.18
compaired to the itr s80 http://www.fatboyraceworks.com...are=1
or same setup with dx/lx 4.058 final drive: and 8000 redline
1st - 41.65
2nd - 69.63
3rd - 82.04
4th - 107.51
5th - 144.46
If there was a 2.200 2nd gear made that would even this setup out perfect But there is not.
The 4.058 fd and the 1.944 second make for a semi long 2nd gear. but only 3.15mph taller than the best possaible useing factory parts (zc 2 1.9442nd with si/ex 4.25 fd)
D Tranny guru's chime in...
Modified by spun Vtec at 11:18 AM 4/11/2007
2nd - 1.944 zc 2nd
3rd - 1.650 hf 2nd
FD - 4.25 si/ex
1st - 39.77
2nd - 66.48
3rd - 78.33
4th - 102.66
1st - 44.74
2nd - 74.79
3rd - 88.12
4th - 115.49
5th - 155.18
1st - 41.65
2nd - 69.63
3rd - 82.04
4th - 107.51
5th - 144.46
please explain "move"
are you saying hf second cant be used as 3rd??
is that the only reason this setup wont work (if i ran the zc 5th)
another question: I totally rebuilt my tranny last year with a bearing, syncro kit from standardtransmission.com will the my cable si syncros work if i use the "classic setup" and just run the si fd and 5th gear with the zc 2,3,4?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun Vtec »</TD></TR><TR><TD CLASS="quote">
Yes. Mainshaft second is machined directly on the shaft. It cannot be moved into third gear location.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">
Yes. Mainshaft second is machined directly on the shaft. It cannot be moved into third gear location.</TD></TR></TABLE>
thanks! now back to the drawing board
pfsmith99
Aug 19, 2012 01:46 AM
B18C5-EH2
44
Jul 6, 2004 04:54 PM
b17gsr
20
Nov 28, 2003 05:19 AM
