control arm difference between trim levels?
Old Apr 10, 2007 | 08:40 PM
dafuzzbudd's Avatar
Default control arm difference between trim levels?
think i can assume the answer,
but wanted to ask if there's a difference between ex, dx, lx
Old Apr 10, 2007 | 08:46 PM
NathanMorris's Avatar
Default Re: control arm difference between trim levels? (dafuzzbudd)
I know the 99-00 Si has lighter weight stamped steel control arms with a different design and thicker sway bar (uses different mounting system too, and different forks)...they are about 2lbs lighter each if I recall my measurements correctly. This is for the front only. rear are the same as the rest of the models, just have a sway bar attached of course.
The ones you listed are all the same, I -believe- the CX lacks a sway bar but someone who knows the hatches better will have to chime in on that.
Nathan
Old Apr 11, 2007 | 12:05 AM
BlueIntegraBoy's Avatar
I am assuming you mean 5th, if so, there are no differences between the rear LCAs except for the EX-S (with ABS). The EX-S has the sway bar endlink holes.
Old Apr 11, 2007 | 04:36 AM
dafuzzbudd's Avatar
yup 5th, should have mentioned.
thanks
Old Apr 14, 2007 | 07:58 PM
Felliph3's Avatar
Default Re: (dafuzzbudd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd &raquo;</TD></TR><TR><TD CLASS="quote">yup 5th, should have mentioned.
thanks</TD></TR></TABLE>
Nice sig lol,i dont even remember me posting that but im sure it was some riced out car.Soo many people have my sig ahaha
HustonB
13
Jan 3, 2013 11:36 AM
hondacurious
Jul 25, 2010 08:49 PM
ekim952522000
22
Nov 24, 2006 02:07 PM
andyvaj
Mar 18, 2005 09:51 PM
jtl
Apr 1, 2004 04:24 PM
