power steering prob
I have an 89 accord lxi and i am loosing alot of fluid whenever i turn right i need to know where to look so i can fix the problem , i did consult the book but it did not give any diagrams can any one help?
I dont know anything about older accords with the a series engines but if you just find where the leak is you can find out what you need. It coiuld be a cracked line or its leaking from a fitting or whatevr. All you got to do is fill the PS resivor, turn the wheel all the way right and take a look under the hood to see if you can see where its leaking from.
-Eric
-Eric
sounds like your having a power streering pressure hose bad, this is why it happens only when turning the wheel. if it was a return line it would leak all the time. P/S hose is cheap call Autozone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by power11 »</TD></TR><TR><TD CLASS="quote">do you really have to use "genuine honda" power steering fluid on a 2000 accord. csaue it says that ontop of the cap</TD></TR></TABLE>YES. It's different stuff.
There's a couple brands (besides dealer) that make PS fluid for Hondas. But you have to make sure it says "FOR HONDA & ACURA CARS" on the bottle. Anything that claims to work for all makes, don't believe it.
'06-V6-MT
Jun 30, 2015 05:47 PM
illicon2003
Mar 20, 2004 01:38 PM
