Help to get oem piston off rod?
Old Apr 10, 2007 | 04:48 PM
hemlockz's Avatar
Default Help to get oem piston off rod?
I'm trying to get an oem F22/H23 connecting rod that was pulled from an F22A1 from a 92 accord. I can't get the piston off. I heated up the rod with a propane torch and slammed a socket down onto the top of the wrist pin with a hammer and it was solid as a rock. I looked at it for awhile and it looks like there are two pieces of the wristpin, one for each side, and they are pressed into the rod and divided by a ring thats part of the rod or something? help?
Old Apr 10, 2007 | 04:51 PM
Jay_Sensing's Avatar
Take them to a machine shop man. They are pressed in and out. I am sure if you beat/heat enough you can get them apart but I personally wouldn't want anything in my motor moving that fast to have been beat with a sledge hammer.
Old Apr 10, 2007 | 04:56 PM
hemlockz's Avatar
Default Re: (Jay_Sensing)
I'll never run it. I can get H beams or shot peened OEM for the same price and for all motor I want to know what the weight is of the oem rod. Its not online, and I have this piston lying around so I'm trying to get it off the rod. at this point i'm just screwing around... now its like a game, me vs wristpin(s)? is it 2 pieces like it looks>?
Old Apr 10, 2007 | 05:09 PM
Oh I see, in that case, I would think you are on the right track man but I think it takes over 5000 psi to move that pin. I can't remember what the machine shop said when I was in there.
Old Apr 10, 2007 | 05:21 PM
hemlockz's Avatar
well it sure didn't work like it did on the omniman dvd
Old Apr 10, 2007 | 05:52 PM
hemlockz's Avatar
Default Re: (hemlockz)
okay its half way out. I think this torch just sucks ***....
Old Apr 10, 2007 | 05:58 PM
Natural Aspirations's Avatar
Yea you just need to get it hot enough. It will slide out smoothly. You will notice a purplish color when it is hot enough.
Old Apr 10, 2007 | 06:24 PM
hemlockz's Avatar
Default Re: (Natural Aspirations)
my torch sucks... I got it out finally, but bent the rod in the process. heated it for 5 minutes or so then used a 1/2 inch extension and socket and beat the expletive outta it. after about 50 hits it fell out. I only hit the piston twice. thanks everyone
Modified by hemlockz at 4:00 AM 4/11/2007
GoodSkoolRevltn
34
Mar 15, 2014 10:58 AM
Mhollaek9
Sep 1, 2007 03:06 PM
tarheelsoldier
Feb 19, 2007 11:36 AM
Speed Infliction
May 1, 2006 07:24 PM
dennis
Dec 16, 2002 03:37 PM
