hissing noise
hey guys, iv noticed a really annoying hissing noise when i am giving the car full throttle, what can it be? it sounds like its coming under the car, but i recently checked if there is any holes in the exhaust and if everything is tight which it is, so is there anything else i should check?
intakes hiss loudly at WOT... but exhaust leaks also hiss. When you start your car in the morning its easiest to check for leaks because the water evaporating from your exhaust makes the exhaust white... have someone rev the car while you look underneath
there is something inbetween the down pipe and the kat. take the kat off. and there should be like a washer or someting, i forgot the name of it. but i had teh same problem, we reversed the thing on the end of hte kat, and the noise went away. its a 10min fix
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92Vteg »</TD></TR><TR><TD CLASS="quote">there is something inbetween the down pipe and the kat. take the kat off. and there should be like a washer or someting, i forgot the name of it. but i had teh same problem, we reversed the thing on the end of hte kat, and the noise went away. its a 10min fix</TD></TR></TABLE>
It's called a donut gasket
AguaFina_FB6
Honda Civic (2006 - 2015)
Apr 28, 2016 07:17 PM
96AccordExCpe
Jun 25, 2003 11:33 AM
