Replacing front sway bar end-link
Old Apr 10, 2007 | 03:28 PM
rocket30004's Avatar
Default Replacing front sway bar end-link
So mine is busted. I was going to replace it but had 1 question:
On the side attaching to the sway bar, you put a hex key in the actual bolt where the nut fastens onto, but it impossible to fit a socket over that... you could use a ratchet-wrench or just a regular wrench, but I wouldn't be able to tq it down to whatever is specified by the factory... unless I am missing something here?
How do I get about torquing it down to spec?
Old Apr 10, 2007 | 03:34 PM
117's Avatar
117
Torque to spec using a crow's foot.
Old Apr 10, 2007 | 03:39 PM
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">Torque to spec using a crow's foot.</TD></TR></TABLE>
Ahhh!! I can't believe I didn't think about that... good call!
Old Apr 10, 2007 | 07:25 PM
TheWalrus's Avatar
you can also get it snugged tight and then torque it with a regular socket...once its tightish, the ball joint part is held against the bar so it wont spin
Old Apr 10, 2007 | 07:29 PM
Mr.Luder's Avatar
How do i know if mine is busted. I don't see any damage visually but I can hear a slight clunk when I accelerate from a dead stop and only from a stop. It's just one clunk from a stop and than its fine. Lemme know. Thanks
Old Apr 11, 2007 | 08:40 AM
Default Re: (Mr.Luder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Luder &raquo;</TD></TR><TR><TD CLASS="quote">How do i know if mine is busted. I don't see any damage visually but I can hear a slight clunk when I accelerate from a dead stop and only from a stop. It's just one clunk from a stop and than its fine. Lemme know. Thanks</TD></TR></TABLE>
I had a clunk/pop when turning (sometimes) and more often when I go over bumps. It started after I went over a pot hole. Took of the front wheels a few days later and the end link was sheared right off the side. (at the joint where it turns 90*)
Default Re: (TheWalrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheWalrus &raquo;</TD></TR><TR><TD CLASS="quote">you can also get it snugged tight and then torque it with a regular socket...once its tightish, the ball joint part is held against the bar so it wont spin</TD></TR></TABLE>
Thanks also.. I wasn't sure if it would still spin or not...
needtoknow
Suspension & Brakes
Nov 27, 2007 06:18 PM
coolpix99
Dec 27, 2005 09:39 PM
Lo-Buck EF
26
Aug 24, 2004 07:20 PM
tokyoracer
Aug 9, 2003 04:08 AM
