Did seafoam ruin my engine?
Old Apr 10, 2007 | 01:56 PM
lax1089's Avatar
Default Did seafoam ruin my engine?
97 ex
this may sound dumb but very soon after i put in seafoam on an empty tank and then filled it up i started noticing a decrease in power and t hasnt gone away. was i not supposed to put it in the tank? whats going on!!!
Old Apr 10, 2007 | 02:08 PM
Loco-B's Avatar
Default Re: Did seafoam ruin my engine? (lax1089)
Whats seafoam? Your not talking about gas tank cleaner crap are you?
edit: that doesnt look like a product you should be placing anywhere near a car. I don't know about you but the only thing that goes into my gas tank is gas
Old Apr 10, 2007 | 02:13 PM
Bruce Banner's Avatar
Default Re: Did seafoam ruin my engine? (accordcd_7)
Old Apr 10, 2007 | 02:37 PM
twotonecivic's Avatar
Default Re: Did seafoam ruin my engine? (Bruce Banner)
they make seafoam automotive additive ****. that's wierd, i wouldn't think that would be ur problem.
Old Apr 10, 2007 | 02:50 PM
lax1089's Avatar
Default Re: Did seafoam ruin my engine? (twotonecivic)
yeah well i got te automative **** of course. i picked it up at autozone i remember someone on this forum saying it gave them at least 2mpg after they did it
Old Apr 10, 2007 | 03:22 PM
Twixle's Avatar
ate my pixel
Did you read the directions on it? How long ago did you put it in, it's very possible that you'll regain the power once it gets worked out of the system, try running your car down to E and then refueling.
Old Apr 10, 2007 | 03:25 PM
Default Re: Did seafoam ruin my engine? (accord2021)
seafoam werks for me
Old Apr 10, 2007 | 03:30 PM
Tech-Nics's Avatar
can you be more specific regarding "decrease in power" what is happening that you are coming to this conclusion...???
Old Apr 10, 2007 | 04:30 PM
lax1089's Avatar
Default Re: (Tech-Nics)
basically it feels like i have to press harder on the gas to get the same speed especially in the first three gears. im not saying i KNOW its the seafoam but it just started around the same time.
the bottle didnt have directions but it did say what would happen if put in the gas tank (clean the injectors)
Old Apr 10, 2007 | 05:28 PM
Stealthman80's Avatar
Default Re: (lax1089)
no its not the seafoam
Old Apr 10, 2007 | 05:52 PM
gulfview's Avatar
Default Re: (Stealthman80)
Sometimes an addative like Seafoam, especially a whole can, will loosen up gunk in the gas tank. You might want to change your fuel filter.
Old Apr 10, 2007 | 06:22 PM
pos_cd5's Avatar
Default Re: (gulfview)
seafoam works wonders for me, and everyone else i know. just follow the directions ...your only suppose to mix so much per gallon of gas, maybe you over diluted your gas?
Old Apr 10, 2007 | 06:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lax1089 &raquo;</TD></TR><TR><TD CLASS="quote">
the bottle didnt have directions but it did say what would happen if put in the gas tank (clean the injectors)</TD></TR></TABLE>
The bottle actually does have directions.
Did you pour the whole can into the fuel tank?
Old Apr 10, 2007 | 07:14 PM
lax1089's Avatar
Default Re: (Bruce Banner)
yes i did because the autozone guy told me to after we both scanned it for directions
Old Apr 10, 2007 | 07:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lax1089 &raquo;</TD></TR><TR><TD CLASS="quote">yes i did because the autozone guy told me to after we both scanned it for directions</TD></TR></TABLE>
DING DING DING!
THE WINNA!
This is why your car is fukked up now.
It says on the bottle pour 1/3 for 12gal of gas.
I hope you learned from this to NEVER listen to autozone people.
pos_cd5's Avatar
i came up with a few explanations to this.
1) neither of you can read
2)both you guys need glasses
3)it was a can of pepsi
Old Apr 10, 2007 | 07:22 PM
lax1089's Avatar
Default Re: (pos_cd5)
so wait am i fucked now?
my gas tank is already half empty so should i just fill it up to dilute the seafom????
Old Apr 10, 2007 | 07:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lax1089 &raquo;</TD></TR><TR><TD CLASS="quote">so wait am i fucked now?
**** **** **** ****</TD></TR></TABLE>
lets see here.
bottle says 1/3 per 12 gallons of gas.
so 3X12=36
You would need 36 gallons of gas to dilute it down assuming the fuel filter isn't all fukked up already.
Old Apr 10, 2007 | 07:30 PM
Twixle's Avatar
ate my pixel
that would be advisable. Dilute that pepsi quick!
Old Apr 10, 2007 | 07:31 PM
lax1089's Avatar
okay so how will i know if its fucked up or not? after i fill it up if the problem goes away can i not worry about the fuel filter or should io replace. i heard its a bitch without the right tools (which is my case)
You should fill up the tank 1st.
Old Apr 11, 2007 | 06:18 AM
EXccord's Avatar
lol this should be archived as humor..im gonna quote that guy when he goes "**** **** ****" that was ******* hilarious
Old Apr 11, 2007 | 06:52 AM
GhostAccord's Avatar
I wouldn't worry about it too much...I fog the shyte out of my car with that stuff until it's about to die all the time mind you I direct inject it into my intake. If it's in your tank it will just take a bit of time too work it's way through.......it's the seafoam that is causing the low power....buy itself seafoam will actually make your car stall out or quit, so right now you have enough of a mixture to at least run your car...if your @ half a tank now I would fill the tank the rest of the way with premium/higher octane fuel and you should be fine. may still act a bit weird but to be expected with a full can in there. Run it down to E and fill your tank with regular gas. By this time your whole FI system should be pretty clean, you may need to replace your filter as mentioned above.
Old Apr 11, 2007 | 07:16 AM
cpmike's Avatar
lol.
yes, there are directions on the can... on the back. and never get advice from autozone employees.
that aside, seafoam is 100% petroleum based and is not harmful to your can in any way, unless you dump too much into the intake and hydro lock your engine.
just burn off that tank and fill up with fresh gas.
its made to be used in gas, oil, diesel, intakes, everything... its a petroleum based carbon cleaner. i used a can of it on every swap i do, as well as every so often on my own car, always had great results. one time i was throwing O2 and Fuel Supply codes, and a can of seafoam thru the intake cleared them, never to be seen again...
great product...
Old Apr 11, 2007 | 07:35 AM
JDM_CD7's Avatar
Default Re: (cpmike)
Ohh man (LOL)
I'm dying over here.....
How can you put something in your gas tank or car period without reading the instructions or what the product may do to the car.
I've used seafoam for about 5-6 years on more than 30 cars and all had great results *****When used correctly****
Now in your situation, I believe you should empty your gas tank manually and possibly run the highest octane you have in your state to clear all the Seafoam out.
Good luck, and take a couple of seconds next time to read.
