HELP! asap after egr port cleaning
Old Apr 10, 2007 | 12:01 PM
honda369glow's Avatar
Default HELP! asap after egr port cleaning
I drive a 97 honda accord non vtec and after i did all the egr port cleaning and started the car and the car revs up and down from 2.5-3k rpm. I tried resetting the ecu by unhooking the battery and tried again and still reving up and down. I need help asap. Need a car to drive.
Old Apr 10, 2007 | 12:03 PM
bonh's Avatar
there's a diy on here for the other valve.. i forgot what its called but it sits behind the head..
Old Apr 10, 2007 | 12:22 PM
Default Re: (bonh)
can u be more specific, diy? is it a plug?
Old Apr 10, 2007 | 12:45 PM
Old Apr 10, 2007 | 01:10 PM
bonh's Avatar
https://honda-tech.com/zerothread?id=1003988
fast idle thermal valve
Old Apr 10, 2007 | 03:40 PM
Default Re: (bonh)
tried fast idel thermal valve still not working! help
Old Apr 10, 2007 | 03:44 PM
hondadude's Avatar
Default Re: (honda369glow)
did you pull off any extra vacum lines, when you were doing the EGR clean job?
IACV plugged back in?
Any leaks around the injectors?
Old Apr 10, 2007 | 06:30 PM
Default Re: (hondadude)
everything is in place, no leak...when i start the car it idles high at like 2k rpm and then after a min when warmed up there is goes rpm going up and down. wtf
Old Apr 10, 2007 | 07:42 PM
hondamanwill's Avatar
low coolant?
Old Apr 10, 2007 | 07:48 PM
The-Kid's Avatar
Irvine? LOL i live in Irvine.
Hmmmmm FITV is tighten all the way down. IACV is your last place to look at. Check the connection as Hondadude said. Did you put the EGR plate and it's gasket the same way?
Make sure all the connection is all the way plugged in. And nothing is blocking any intake passage. I did this EGR port cleaning and nothing happen.
Old Apr 10, 2007 | 08:03 PM
lax1089's Avatar
Default Re: (The-Kid)
so did i. it ran a lot smoother. i guess it could be easy to put the egr housing and gasket back on the wrong way if you arnt paying attention. my idle is fucked too and im getting ready to work on the FITV
Old Apr 11, 2007 | 04:21 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: HELP! asap after egr port cleaning (honda369glow)
try cleaning the iacv
https://honda-tech.com/zerothread/1844067
Old Apr 11, 2007 | 11:05 AM
Default Re: HELP! asap after egr port cleaning (TouringAccord)
thanks everyone, I FIXED MY CAR, the egr port plate wasn't even tight! it was hand loose, after i tightened it was all good, what a dumbass.
Old Apr 11, 2007 | 11:06 AM
The-Kid's Avatar
Ha i was right. Muahahahaha.
Old Apr 11, 2007 | 04:55 PM
here is a pat on the back for you.
Old Apr 11, 2007 | 06:26 PM
The-Kid's Avatar
Default Re: (hondamanwill)
ROFFLES heres a pat on the back for you too for patting me on the back.
Old Apr 14, 2007 | 09:35 PM
cease805's Avatar
Default Re: egr chamber gasket
do i need a new egr chamber gasket after i clean it out?
thanks
joshuma
Sep 2, 2008 05:37 AM
christhereefer
Jan 4, 2006 03:19 PM
gnar kill
Jun 29, 2005 01:21 PM
G U E C O
Dec 28, 2003 01:56 PM
