h22 base map program
Old Apr 10, 2007 | 10:30 AM
Hwj_33's Avatar
Default h22 base map program
Does any body know where I can get a copy of a h22 base map program? I have a p28 ecu that is chipped with gsr specs. Vtec is at 5800 and it redlines at 9000. Now I have a h22 and I want to use the same ecu but need to change the chip to run h22 instead of gsr. Need some help?
Old Apr 10, 2007 | 12:06 PM
mmuller's Avatar
Mad Scientist
Default Re: h22 base map program (Hwj_33)
http://www.pgmfi.org
Old Apr 10, 2007 | 01:17 PM
BEST1TUNING.COM's Avatar
Default Re: h22 base map program (mmuller)
I can get you a basemap that I have used in H22's that should be close...most basemaps need a certain degree of tuning but are good starting points. If you are using a p28 and want to keep your secondary intake runners (IAB's), the ecu needs to be modified slightly to handle control of the secondaries.
night_mare92
Oct 8, 2010 06:34 PM
meanshyguy
Aug 10, 2008 08:39 AM
turbogsr18
Engine Management and Tuning
May 18, 2008 08:00 PM
IA95civicDX
Aug 12, 2007 03:38 PM
racerpat94
Mar 19, 2007 04:29 PM
