1999 TURBO INTEGRA GSR FOR SALE. BUILT ENGINE. TUNED. QUALITY PARTS NEVER RACED
Serious inquires only! Will not let you drive it! I will take you for a ride if you have the money. I have vouches/ Never raced! $15,000 obo Has show car potential, a little more boost, slicks or drag radials and you got a 11 second car. Has great potential for less.
540-287-6813 leave a message remember serious inquiries only. NOT PARTING OUT
-Parts were installed my Honda Master Tech can provide his contact info.
-Shortblock assembled by TorqueFreaks in Portland, Oregon
-Blocked sleeved by Golden eagle
-Block has 5800k miles is in perfect working order. NO PROBLEMS AT ALL
-ALL PARTS ARE NEW WITH LESS THAN 1000 MILES ON THEM
-Fully Dyno tuned at Pro-motion Tuning by Chris Treblet.
-327 wheel horsepower 232 torque at 8psi
-Stock GSR p72 head 79k. Has valve adjustment to stock specs
-Body has 79k on it
-13k invested
Engine components
Drag turbo manifold
Drag chrome charge piping
Precision SC61 (LESS THAN 1000 MILES)
Spoolin Performance 3 inch down pipe
High quality t-bolt clamps
Custom stainless steeel 3 inch exhuast
Apexi N1 Black turbo muffler
Tial 38mm Wastegate
Blitz super sound blow off valve
Johnny Race car 600hp intercooler
Skunk2 Cam gears
Valve cover has moon shapes cut to see cam gears and for adjustment
Golden Eagle Vacuum Manifold
STR polished intake manifold
84MM gsr block with Golden Eagle Godzilla Sleeves, Copper O-ringed, 84mm Arias 9:2:1 forged pistons, Eagle H beam rods w/arp bolts, ACL race bearings, balanced and blueprinted, gsr crank micro polished and chamfered.
Golden Eagle 84mm Headgasket
Golden Eagle head studs
Honda valve adjustment to factory specs
New Oem Valve cover gasket with grommets
New Oem Oil pan gasket
New Oem Honda cam seals
New Oem Honda timing belt
New water pump
Flex-a-lite dual slim line fans
Aem fuel rail w/ liquid filled fuel pressure gauge
Aem adjustable fuel pressure regulator
Rc 750cc saturated injectors
Nology Hotwires
Msd SCI ignition
Msd blaster 2 coil
Msd distributor cap
Electronics
AEM uego wideband o2 sensor with 52mm guage
Autometer boost/vac gauge
Autometer triple guage pod
Hondata S200 with boost, data logging, 3 step rev limiter- Launch control and full throttle shift
Hondata Socketed odb1 p72 ecu
Boomslang obd2a to obd1 conversion harness
Suspension
GR2 Shocks and struts
Brand new KUMHO ECSTA SPT (KU31) Ultra High Performance front tires
Yokohama AVS ES100 on the rear (more than 50% tread left.
Aerospeed Coilovers (lowered 3 inches)
ACT 12LB street light flywheel
Competition stage 3 clutch
Suspension techniques front and rear sway bars with urethane bushings
Energy suspension urethane motor mount inserts
Interior
Sony xplod flip down cd player with changeable images
Factory mint condition black gsr leather interior
Exterior
Factory polished GSR blades
Black paint (original)
Gsr factory spoiler
Brake calibers painted red
Custom Integra GSR vinyl sticker (identical to type-r sticker but says Integra GSR)
20% rear black tint, 35% black front tint
JDM Black housing corner lenses
Red Acura emblems front and rear
Very clean, minor rock chips on front lip
Street Glow red neon under car light kit. (lights still mounted, needs to be reconnected)
SLEEPER
Chris at 540-287-6813. Leave a message remember serious inquiries only. NOT PARTING OUT
Modified by chrisgottigsr at 5:21 PM 4/11/2007
-Body has 79k on it
-13k invested
Engine components
Drag turbo manifold
Tial 38mm Wastegate
Skunk2 Cam gears
New water pump
Nology Hotwires
Msd SCI ignition
Msd blaster 2 coil
Msd distributor cap
Electronics
Suspension
Interior
Exterior
Gsr factory spoiler
SLEEPER
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisgottigsr »</TD></TR><TR><TD CLASS="quote">whats your email address. pm it to me</TD></TR></TABLE>
pm'ed
pm'ed
pics
http://i177.photobucket.com/al...r.jpg
http://i177.photobucket.com/al...c.jpg
http://i177.photobucket.com/al...e.jpg
http://i177.photobucket.com/al...s.jpg
http://i177.photobucket.com/al...1.jpg
chrisgottigsr
Southeast (Sales)
11
May 3, 2007 05:28 PM
chrisgottigsr
Mid-Atlantic (Sales)
14
May 3, 2007 05:27 PM
chrisgottigsr
May 1, 2007 11:37 AM
chrisgottigsr
Apr 16, 2007 02:52 PM
