Car Alarm is My Horn???
Old Apr 10, 2007 | 08:59 AM
Shay91Racer's Avatar
Default Car Alarm is My Horn???
I bout this car..91 Accord.. and i was checkin everything out. I pressd the horn and it was the sound of my car alarm. i looked under the dash and seen a crimestopper alarm. how do i rewire it so that i'll have the alarm, for an alarm and not my horn?
Old Apr 10, 2007 | 09:33 AM
suspendedHatch's Avatar
Default Re: Car Alarm is My Horn??? (Shay91Racer)
They must have your negative horn wire tripping a relay that sends power to the siren. You don't have to worry about any of that. Just go to your column and find your horn wire. It will be cut, so just reconnect it and disconnect any aftermarket wiring to it. I recommend getting hold of a repair manual so you can find the wire color for your horn.
Old Apr 10, 2007 | 12:31 PM
Default Re: Car Alarm is My Horn??? (suspendedHatch)
cool.... I'm going to look for that. Thanks alot
Old Apr 10, 2007 | 01:31 PM
but wait... i went to the junkyard to pull a horn. There are two horns on Accords apparently and the horn i got works fine when i pressed the horn. so wouldnt that mean something else or does the fact still stand? Thx again
Old Apr 10, 2007 | 10:39 PM
Why did you go to the junkyard? Is your horn missing? Why didn't you do what I told you?
Old Apr 11, 2007 | 04:12 AM
i went to the junkyard before hand.. because both my horns were missing and the only horn i had was for the alarm.
Old Apr 12, 2007 | 10:03 AM
well.... thx but i've figured it out... i shouldve noticed a little quicker but i didnt. They didnt slice any wires.. except the connector that connect the wires to the horn. those were cut off exposing the wires and the alarm siren was connected to those wires. thx anyhow.
nitewolf
Audio / Security / Video
Aug 5, 2010 07:03 PM
krytykalintentions
Jan 17, 2007 07:53 PM
arw321
Sep 5, 2003 12:25 PM
technine
Dec 17, 2002 08:54 AM
