HOw do I tell if my ecu is shot?
jeff try switching the 2 white wires on your connector for the distributor. you might have mixed them up. remember one wire with a red mark on it. also look for any loose connections,specially the groundings. check your fuses, it might have burned.your hazard fuse #10 in the engine bay, its most likely that might have burned. check other fuses under your steering wheel too.
if all fuses are ok, what you want to do is try another si ecu. peace and good luck.
[Modified by vsual, 6:49 PM 5/27/2002]
[Modified by vsual, 6:50 PM 5/27/2002]
flat-blk-HB
10
Dec 12, 2020 12:13 AM
Quick.Silver
May 24, 2006 11:56 AM
poundedhatchcrap
Jun 20, 2005 07:23 AM
