~~~~~~~~TW 96 INTEGRA GSR ~~~~~~~~~~~~~~~
Testing waters right now. I will sell if the price is right.
96 integra gsr motor has about 20k on it since assembled
clean title paint is about 3 months old
Specs:
ALL parts are OEM Honda unless specified below.
GSR head:
Machine work by Sal automotive
ITR intake arm w/ K&N filter
Blox intake manifold w/ 68mm RPM throttle body.
TB cable convertion ( yes , the right way oem style)
hondata gasket
440cc RC injectors
RPM TB 68mm
JG valvetrain and retainers (good up to 11k rpm on 13mm lift)
REV flat valves (to increase cr….0.3)
new valve seals
B&M fuel regulator
Pressure gauge
Buddy Club 4 cams
Eagle cam gears ( 12 point bolts A+)
New gaskets and seals, pins, every little thingy (oem honda)
AEBS head studs
OEM 81mm head gasket
new vtec selonoid filter
bottom:
B18C1 81mm
p73 JDM pistons / rings (OEM) raised CR
ACL bearings
ARP rod bolts
new OEM water pump & tensioner
walbro 255 fuel pump
timing belt OEM
AEBS main studs
Jaz catch can
ITR oil pump OEM
ITR JDM header with ALL shields (for stock look)
and block braket ( yes , the right way)
HKS firepower exhaust
Magnafow 2.5 cat
ECU:
OBD2 to OBD1 convertion
p28 w/ hondata s200
Eibach springs (cut, sorry it sat way to high for me
Camber kit
energy suspension mounts bushings
P/S A/C works
OEM acura cell phone ( rare to find in stock form, verizon provider)
OEM radio with alpine 6 disc changer in the trunk
alpine equalizer
Fosgate Amp
leather seats
xplod rear speakers
OEM fog lights
16" wedsports w/ falken like new
Specs:
GSR head:
hondata gasket
440cc RC injectors
RPM TB 68mm
new valve seals
B&M fuel regulator
Pressure gauge
Buddy Club 4 cams
AEBS head studs
bottom:
B18C1 81mm
ACL bearings
ARP rod bolts
timing belt OEM
AEBS main studs
Jaz catch can
ITR oil pump OEM
Magnafow 2.5 cat
ECU:
p28 w/ hondata s200
Camber kit
P/S A/C works
alpine equalizer
Fosgate Amp
leather seats
xplod rear speakers
OEM fog lights
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by airmax »</TD></TR><TR><TD CLASS="quote">any motor shots
what is your ball park</TD></TR></TABLE> pmd
Haha what the heck? Never seen a cell phone in any Honda. How does that work? I like how the engine looks completely stock (well except for the fuel pressure gauge and injectors, and that fuel pressure regulator could use a little black touchup paint). Have you dynoed it?
djbutler007
Oct 10, 2007 10:48 PM
djbutler007
Sep 30, 2007 09:29 PM
djbutler007
Jul 6, 2007 09:35 PM
djbutler007
Jul 6, 2007 09:34 PM
djbutler007
Apr 25, 2007 05:33 PM
