dohc zc bogs and dies at half throttle
Engine will not bog at idle, nor when I slightly give it gas. But when I give it half throttle, in nuetral, it revs, drops below 1000rpm, then boggs / and misfires until it dies. I have no clue what could be wrong. I installed a new timing belt two months ago, after snapping my stock one. I have not checked the plugs, but checked the wires, making sure nothing was wrong with them (its too cold outside). Its throwing no codes. I was thinking it jumped timing, but it does not stall unless it is given half throttle. Also, will not crank easily unless I tap the gas. Need help ASAP! school starts back tomorrow and I have no ride
found out what it was, somehow the wires slipped out of the distributor, was too cold and dark to check that last night, they were barely making any connection. thanks.
k0rean4life
Nov 30, 2005 07:32 AM
