pulling trans
Old Apr 9, 2007 | 06:38 PM
innes887's Avatar
Default pulling trans
im going to replace my clutch cus my stock one is f***d. does anyone have a step by step way of doing this cus the chiltons manual tells me to pull a **** load of stuff. do i have to pull off the hubs and cv's commpletely or can i just dissconnect them from the trans. its a 89 crx dx with the 1.5
Old Apr 9, 2007 | 06:50 PM
EF_LSVtec's Avatar
Default Re: pulling trans (innes887)
How can you disconnect them from your tranny if the other end is connected to the hub?
Old Apr 9, 2007 | 07:14 PM
HatchMo's Avatar
Magic.
Old Apr 9, 2007 | 08:55 PM
brandoom's Avatar
An Hero
Default Re: (HatchMo)
Dammit. i just cleaned my monitor...
Old Apr 9, 2007 | 09:53 PM
dandizel's Avatar
Default Re: (brandoom)
^ haha. Just disconnect your lower control arm from the hub, and slide the axles out of the hub, then use your long flat head screw driver between the axle and diff casing and pry out the axles.
Old Apr 9, 2007 | 11:40 PM
EFM_ookie's Avatar
Default Re: (dandizel)
lol... wow
Old Apr 10, 2007 | 04:42 AM
boostedSI90hatch's Avatar
Banned
Default Re: (89_Mangina_SI)
i undo the cv nut then undo the lower ball joint which you do not hammer on the top of the threads of the ball joint you will sandwich it and then the threads are non usable once its separated pop the axle out with a flat head.
even if you tryed to get it out with the axles still in it would bind and then you would be stuck.
sanman000719
Jul 7, 2011 07:47 PM
ugandaHonda97
Dec 15, 2010 12:59 PM
gursh d
Dec 27, 2006 07:15 AM
Blaze45
Apr 16, 2003 07:53 PM
projecthybrid04
Sep 26, 2002 06:38 AM
