Mini-me O2 sensor code...tach no go either
Old Apr 9, 2007 | 06:27 PM
xotic_crx's Avatar
Default Mini-me O2 sensor code...tach no go either
I just finished my a6/z6 mini-me swap, and for about the first 60 miles it didn't throw any codes, but this morning I cranked it and ran for about 10 minutes and it came one. I returned home and cleared the code, then it set off again about 2 miles down the road. I have the haynes manual, but am a little confused as to where to check the volts and ohms.
I'm using a Rywire obd0 -> obd1 conversion harness with a universal 4 wire 02 sensor, which i used butt connectors to connect to a 4 wire connector i cut out of another car.
I checked all of the wires in the butt connectors, and they are in there good.
Also, on a side note, my tach isn't working since the swap. I had occasionally had problems with it not working before, but i would bump the dash and it would begin to work. Again I used the rywire conversion from the dizzy.
Old Apr 9, 2007 | 06:30 PM
mengy007's Avatar
Default Re: Mini-me O2 sensor code...tach no go either (xotic_crx)
sorry to go off topic but how did you check your ecu codes? I recently converted to OBD1 running ZC/vtec with the rywire conversion harness.
Old Apr 9, 2007 | 07:22 PM
xotic_crx's Avatar
Default Re: Mini-me O2 sensor code...tach no go either (mengy007)
2 extra wires on the new harness that don't have plugs, twist them together.
dem0nk1d
32
Sep 15, 2007 11:49 PM
91dx-92ex
Jan 25, 2006 08:37 AM
b18cEF9
10
Apr 27, 2005 01:52 AM
PhatwhipsJDMkits
10
Nov 11, 2004 06:38 AM
Harry_Randal
Jul 13, 2004 06:47 PM
