Fulley Built B16 Block, sleeved,JE,Crower,ACL
Old Apr 9, 2007 | 02:53 PM
b18sihatch's Avatar
Default Fulley Built B16 Block, sleeved,JE,Crower,ACL
im looking to sell my block its fresh never ran it is built with the following:
b16A block
81mm bore
L.A Sleeves Ductile Iron
JE forged pistons 8:5:1
JE Total Seal Rings
Crower H beam Rods (not the cheapos either)
Acl Main bearings
Acl rod bearings
Balanced Rotating assembly
Lighted Rotating Assembly
Unorthadox racing pulley
price i paid for the block and parts are as follows
500.00 for sleeves
550.00 for Pistons
750.00 For rods
2200.00 For machine work
over $4500.00 invested built to handle 550+ all day long looking for $3000.00
Old Apr 9, 2007 | 04:08 PM
BlangBlangTEG-93''s Avatar
Default Re: Fulley Built B16 Block, sleeved,JE,Crower,ACL (b18sihatch)
ARE YOU GOING TO POST UP PICS?
Old Apr 9, 2007 | 06:15 PM
b18sihatch's Avatar
Default Re: Fulley Built B16 Block, sleeved,JE,Crower,ACL (BlangBlangTEG-93')
Also i paid 500 for the block itsself it has really low miles on it before it was sleeved so i have very close to 5k in this
i will get pics
Old Apr 11, 2007 | 07:45 PM
steve00si's Avatar
we need pics and locations
Old Apr 12, 2007 | 01:43 PM
b18sihatch's Avatar
Default Re: Fulley Built B16 Block, sleeved,JE,Crower,ACL (steve00si)
therer are some pictures.
it also has new water pump
timing belt
tensoner
oil pump was checked and is fine
Old Apr 16, 2007 | 11:00 PM
jfrase06's Avatar
do you have everything to do a complete swap like the wiring harness and the ecu and all that?!?!?!
Old Apr 17, 2007 | 07:10 AM
b18sihatch's Avatar
Default Re: (jfrase06)
its the complete block only. i have the wiring harness but that would be extra
Old Apr 17, 2007 | 07:14 AM
jfrase06's Avatar
where are u located???
Old Apr 17, 2007 | 08:01 AM
b18sihatch's Avatar
cincinnati ohio is where im at
the block also has the following:
knife edged crankshaft
New b16 timing belt
tapped for endyn engine breather kit (on back of block)
tapped for turbo oil feed line (on back of block)
Oil cooler (on back of block)
New Honda oil filter (on back of block obviously)
some of the machining is:
Sleeved block
Build bottom end
balance assebmly (including unorthadox race pulley)
Lighten rotation assembly (including unorthadox race pulley)
Deburr Pistons
Machine bottom of sleeves
deck sleeves and block
Hone sleeves
there is closer to 6k in the block now that i have totalled up other new parts that i hadnt before so its like your getting 50% off
Old Apr 17, 2007 | 11:45 AM
jfrase06's Avatar
so what will i need to make this engine run?
Old Apr 17, 2007 | 02:36 PM
b18sihatch's Avatar
head
transmission
wireing harness
ecu
intake manifold
fuel rail
injectors
clutch
flywheel
shift linkage
Car
this is JUST the shortblock and whatever else i stated it comes with
Old Apr 17, 2007 | 06:00 PM
jfrase06's Avatar
so u want 3 grand for the block?
Old Apr 17, 2007 | 06:23 PM
b18sihatch's Avatar
yes, ihave almost 6k in it. it was professionally built with all high performance parts to make 600+whp
Old Apr 17, 2007 | 06:28 PM
jfrase06's Avatar
lil out of my price range, i was looking for a more complete engine, srry if i wasted ur time
spoon93
May 9, 2011 08:15 AM
1fastvik
Jul 7, 2007 02:41 PM
99teggsr
Sep 21, 2006 06:29 PM
fknfast
Jan 25, 2006 07:19 PM
