Fidanza Aftermarket Drive Shafts
Old Apr 9, 2007 | 12:20 PM
UK_Luder's Avatar
Default Fidanza Aftermarket Drive Shafts
I was just scanning through some aftermarket parts for the Lude here, and seen these uprated Fidanza drive shafts. I had a quick search on here and couldn't find any threads on them. They're obviously for high HP applications, and I wasn't thinking of buying them or anything, but just wondered if anyone had come across them before or had any comments on them ?
Old Apr 25, 2007 | 10:59 AM
Da1spaz247's Avatar
Default Re: Fidanza Aftermarket Drive Shafts (UK_Luder)
I'd like to bring this thread back, as I would like to know as well if these axles are any good.
Old Apr 25, 2007 | 12:18 PM
nonvteclude's Avatar
Default Re: Fidanza Aftermarket Drive Shafts (Da1spaz247)
they have a 300 hp rating and they are around $215 an axles. not too sure on the quality of the axle, they seem to do ok in the civic as i have heard from a couple people that use them.
Old Apr 25, 2007 | 12:24 PM
mafia's Avatar
Default Re: Fidanza Aftermarket Drive Shafts (nonvteclude)
are they lighter then stock, or they good cuz they are rated at 300 hp?
Old Apr 25, 2007 | 02:36 PM
Da1spaz247's Avatar
Default Re: Fidanza Aftermarket Drive Shafts (mafia)
I wouldn't care if they were lighter. I'm just tired of breaking re-man axles and if I'm going to upgrade, I want something stronger than stock. The only other one's I know of are the driveshaft shop ones, which are like $750 a pair. These are only like $430 a pair. I'm planning on pushing 400whp, which I know is higher then the fidanza's rating, but they've gotta hold up better than stock ones.
Old Apr 25, 2007 | 06:57 PM
well hp doesnt break axles torque does. also even if hp did your not making 400 hp from the launch so you should be good.
Old Apr 27, 2007 | 06:57 PM
Da1spaz247's Avatar
Ahhhhhh, very good points. I didn't even think of it that way. I'll have to pick a pair up and try them out. Thanks.
Old Apr 28, 2007 | 06:11 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Da1spaz247 &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't care if they were lighter. I'm just tired of breaking re-man axles and if I'm going to upgrade, I want something stronger than stock. The only other one's I know of are the driveshaft shop ones, which are like $750 a pair. These are only like $430 a pair. I'm planning on pushing 400whp, which I know is higher then the fidanza's rating, but they've gotta hold up better than stock ones.</TD></TR></TABLE>
You get what you pay for. Fidanza's aren't going to come close to the DSS axles.
Old Apr 28, 2007 | 07:54 AM
Da1spaz247's Avatar
Default Re: Fidanza Aftermarket Drive Shafts (PrecisionH23a)
I'm willing to bet they arn't as nice as DSS axles, but I need to know if they will be adequet for my car. You get what you pay for holds true for most things in life.
gniddy
Jun 1, 2008 08:00 PM
blackstar
Sep 23, 2003 07:58 AM
stRtypR25
Dec 27, 2002 03:07 PM
TrueZen
Sep 27, 2002 03:42 PM
The Punisher
Oct 16, 2001 04:44 PM
